Tiling over 22mm T&G chipboard
If you are installing Quartz then I would use Tile Master Ultimate as the adhesive.
I personally would fix tile backer board 10mm over the T&G floor. Fixed with adhesive and screws. Its easier to worth its that Hbacker.
Thats what I would do.
Hi McLovin,
I've heard a few people singing the praises of tile master ultimate. Is it a two part?
You could use it over Chipboard if you wanted. I personally would not. Its more work that standard adhesive. 22mm chip board should be fine in my opinion. However personally I don't ever like tiling over chipboard.
I would use a good flexable adhesive under the Backer board and then Tile master S2 to fix the quartz.
Id let the boards dry over night before you start to install the Quartz.
Thanks, so under the backer board what would you use?
Mark1979,
Dav3yboi,
Mark1979,
Dav3yboi,
