Discuss Cutting Porcelanosa Oxo Deco Blanco in the DIY Tiling Forum area at TilersForums.com.
R
Russ
What's the best method of cutting these tiles?
PORCELANOSA Grupo - Mosaics And Decorations - Oxo Deco Blanco Pv 31,6x90 - http://www.porcelanosa.com/finder/Mosaics_And_Decorations_13/Oxo_Deco_Blanco_Pv_31,6x90.html
They are going on a feature wall in the bathroom, I have a cheapo wet cutter but given their length I was looking to borrow/rent/buy a dry cutter (sigma) to help me get nice clean straight cuts. I'm not sure it will work though given the relief pattern though. Any advice?
Russ.
John Benton
1,138
Leeds
If your main field tiles are a flat tile make sure you fix those first and the feature tile up to them. If you do it the other way round you wail have gaps all over the place, unless you can scribe the tile in!!!
Practice siliconing on offcuts as well prior to the actual finished job. I used masking tape on the pic below as the Fugi finishing tools are no good on this type of tile
R
Russ
Thanks for the advise, the other tiles are marmi china, so the same size in a flat matt.
martin1c
633
Cheshire
I've done loads of Oxo Deco and always dry cut with a Sigma. As John says, just do the Marmi first then the deco. Grout & silicon will sort the rest out.
Reply to Cutting Porcelanosa Oxo Deco Blanco in the DIY Tiling Forum area at TilersForums.com
