Brick Bond (Metro) advice
Z
Zub
Hi all,
First time tiler. Decided to tile the kitchen after a fire destroyed the old one.
I need a bit of advice as to which layout I should use for the pipe which has been boxed in.
Do I ignore the bond on the arch, split each side of the boxing into half and brick bond? Or do I continue the bond from the archway? If so, how? I've attached a few sketches below. Sketch 3 looks the most appropriate to me, however that would go against what I have on right corner.
Help!
Thanks in advance
I personally would do the same as @Andy Allen suggested. Some layouts although looking wrong, will look right.....
.....if that makes any sense!!??
Many thanks for your prompt responses
Plan Tec/Andy/Sean/Localtiler
Does this look better?
I forgot to mention one thing, the 'boxing is' 24cm x 24cm, so it wont be a 'full tile' as such. Dont think I can avoid cuts no matter what. I've got plenty time tho so I dont mind.
DIY Tiling Forum
Zub,
Dan,
Zub,
Dan,
