Discuss Removing Squaredged tile-trim. in the Canada Tile Advice area at TilersForums.com.
Steve
138
South Manchester
Have a customer who has had a bathroom tiled with some of it only half tiled 2 months ago , she has decided that she wants it all tiled . Has anyone got a proven method for removing square edged trim without chipping or loosening the existing tiles so I can fully tile it . There 660x300 porcelain so removing any would not be what I want to do as would possibly tear up plasterboard etc , advice ????
Bond
518
Highland
I would try , multi tool with appropriate blade. Or try angle grinder, with a steady hand. :cool:
Andy Allen
1,318
Gloucester
Last time I removed some trim I just used a Stanley knife.......worked a treat, just be carefull you don't cut yourself...
Probably get forum members posting you pictures of there Stanley knife injuries, just to emphasise the BE CAREFULL bit...:)
Time's Ran Out
I'am assuming it's metal square edge trim in which case a hammer and strong sturdy scraper.
Steve
138
South Manchester
No , it's metal , so the trim is tight to the porcelain , not sure I will be able to safely prize the trim away from porcelain if the adhesive has got it good without damaging anything .
Reply to Removing Squaredged tile-trim. in the Canada Tile Advice area at TilersForums.com
