Yeah it's @ISOMAT UK flowcrete 1-10Isomat? Looks ok I guess😉
Useable as a finished floor and can be coloured if you like.
It literally comes down to who you buy it from and how much Bussiness they do with that manufacturer, so the price of these products can vary a lot from that and promotions that may be running at any one time. These products are all priced to compete with each other at source at the end of the day. I find myself maybe using Tremco for several months then I could be over to Uzin or FBall etc etc from a different supplier for the next few months depending on these factors. The soft flooring trade goes through a hell of a lot more of these materials than hard tiling so the volumes that these products are stocked in by suppliers at different times can greatly change the price they can offer at any one time. I try to buy at least one pallet at a time as a minimum so I do haggle and shop about. In wide open areas a floor layer could typically lay 8-10 times more area in a day than a tiler so the volumes of material used is far greater hence the ability and necessity to haggle and shop around. What I would say is though that most soft flooring products aren't necessarily designed for hard tiling demands. A lot of the products have depth limits of 10-15mm per coat whereas typically a good 'tiling leveller can goto depths of 30-80mm because the demands of a tiler is for a flat floor whereas for a Floorlayer it's more important to a certain extent to be smooth more than flat, hence the comments above about laying soft flooring on 'glass'.Where are uzin tremco and fball at price wise lee?
Same sameI buy by the pallet
You swine! HahahaExplain @hmtiling!
Do you let the 2 x 1 rest on the ground and pull it or raise it up a bit and pull it?I tried doing that briefly with my spirit level but it didn't seem to work for me very well.I like to mix a minimum of two bags a time if the floor's big enough, I push the poured levelling mix into the corners with a trowel then let it flow back a bit and then tamp it with a straight length of 2 x 1 pse, usually a 5 foot length does it for me.
Guy i worked for used to do it like that.His floors were very good.Was the reason i have done so little of it because he always did the latexing.Mate that's the worst screeding advice I've ever heard. It didnt seam to work coz it won't. Sound more like block paving lol
