Montolit News Montolit Tilers Tools | Montolit tiling tool news and reviews
This reminds me- i used the new dna blade this week. Tasty looking thing it is too.
In all honesty though, it's no improvement on the marcrist akkumax blades that I've used this past year. It's thicker, stronger too, so less chance of ruining it with a knock (as i have with the akkumax).
So my opinion is this:
upside: it cuts as cleanly as an akkumax, it's a bit thicker, certainly stronger.
The downside is the thickness means it's a bit (little bit) slower, and on cordless you won't get as many cuts.
It's also more expensive. Another 10+ pounds.
I've so far only used it on porcelain. I suspect it's going to be much better than the akkumax on stone though, due to its additional strength...
I'm pretty careful with my tools but i don't like the delicate build of the akkumax. on balance, the dna evo3 is a better blade. if it was the same price as an akkumax it would be a clear winner though.
Same as Raimondi, identical yes?
Have you seen this?
It's a £1000
Product Description
Bevel Ease chamfers and stress relieves rough holes in glass, ceramic and porcelain tiles.
Diamond bit for a smooth, high-end finish.
Very useful to reduce the risk of cracking with standard and large format tiles subjected to tension (ex tightened plumbing, led lights etc)
Very useful to improve the edge finishing of exposed holes
Dry or wet use
Grinder use with separate adaptor
Adaptors are also available for drill machines
Item codes:
FPS35
(for holes from 5mm (3/16") to 35mm (1 - 3/8")
FPS75 (for holes from 35mm (1 - 3/8") to 75mm (3")
NOTE! This is not a core bit for drilling. It doesn’t make the hole but it bevel the hole only.
Product Description
Dry or wet use
Item codes:
FPS35
ordered...
Montolit
Italy,
Italy,
Italy,
Italy,
