Discuss Dural ci fh first time use in the Tiling on Underfloor Heating area at TilersForums.com.
I want to use dural ci fh on a job soon . Now the mat is suited to wires from 2 to 5 mm but what is was wondering was what do you guys do who have used this or ditra e heat or vario pro do when it comes to cold tail connection as it is obviously fatter around 8 to 10 mm .
Many thanks .
Uheat - Jake
TF Official Sponsor
743
It's not the same product however it's the same kind of install method, take a look at our video. Around 1.20 in the video is the cold tail section.
Actually looked and saw what they did with termination point of cable but from what I saw I couldn't see a joint between cold tail and heat cable .
Reply to Dural ci fh first time use in the Tiling on Underfloor Heating area at TilersForums.com
