Discuss Dural ci fh first time use in the Tiling on Underfloor Heating area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
I want to use dural ci fh on a job soon . Now the mat is suited to wires from 2 to 5 mm but what is was wondering was what do you guys do who have used this or ditra e heat or vario pro do when it comes to cold tail connection as it is obviously fatter around 8 to 10 mm .
Many thanks .
Just cut it in to the mat/insulation board.
Thankyou
It's not the same product however it's the same kind of install method, take a look at our video. Around 1.20 in the video is the cold tail section.
Thanks. Will do later
Actually looked and saw what they did with termination point of cable but from what I saw I couldn't see a joint between cold tail and heat cable .
Reply to Dural ci fh first time use in the Tiling on Underfloor Heating area at TilersForums.com
