Discuss Advice Needed - Please be gentle! in the Tanking and Wetrooms area at TilersForums.com.
Chunkydoc
Greetings and Salutations.
As above, looking for some guidance/advice really.
Just in the process of a loft conversion and we decided on a wet shower area.
Ordered this kit:
Wet Room Kit & Shower Screen 1200 x 900mm CENTRE Drain | Wetrooms Online - https://www.wetrooms-online.com/wet-rooms-online-store/wet-room-kits/wetbase-standard-wet-room-kit-and-shower-screen/wet-room-walk-in-shower-tray-kit-centre-drain-1200-x-900mm-shower-screen-detail.html
Plus some Mosaics from Topps for the floor (Shapes Hexagon Unglazed 23x26mm)
Now, and this is where it gets interesting.
Builder sub-contracted the tiling. Said tiler arrived to do the floor, did it and left. Being incredibly picky, I went to investigate and noticed the tiles were BELOW the drain level. Apparently he couldn't put anymore adhesive in as it would have come through the joints, so this prompted a phone call to the builder who said he'd resolve. His resolution was to remove the tiles 300mm around the drain raise the level and put the tiles back.
To be honest, it's all a mess. I have areas of standing water because I have low spots and when the lows spots are overwhelmed the water is heading away from the drain into the opposite bloody corner.
With the experience you fine folk have, is it a lost cause and it all needs ripping up and doing again?
Apologies if there is a lack of information, happy to answer any questions.
Chunkydoc
The drain height was set, though there was an adapter to make it higher if needed.
No pictures on me, but will take some tonight and post them up.
Thanks.
If I had turned and saw drain was higher than tiles and realised it couldn't be lowered I would of stopped at that point . Probably looking at lifting floor and redoing even if you can lower drain .
Chunkydoc
Alas, the drain can't be lowered. This was the first thing I asked.
It's all rather frustrating this close to xmas!
Time's Ran Out
It's frustrating anytime of the year!
Are they extremely thin mosaics? Without compromising the falls within the tray they should have been built up to the outlet level before being fixed. It's no good blaming the adhesive thickness that shows a lack of experience by the fixer.
Any area of standing water need to be resolved so keep on to your builder until your satisfied ( didn't use happy).
MTiler
Is the preformed shower base suitable for mosaics? Some bases arent suitable for mosaics under 30mm because of point loading.
There's no excuses on the tilers part here, if he couldn't Acheive what's required then he shouldn't have stuck a tile down. I would get the lot up and start again. I'll bet the tiler thought sod it not my problem and didn't want to loose his days wage. What size are the mosaics
Your not wrong
Bill
Even the Topps Tiles CGI photo has the drain higher than the tiles for this product...........the mind boggles.
Shapes Hexagon Matt White 23x26mm Mosaic Tile | Topps Tiles - http://www.toppstiles.co.uk/tprod45336/shapes-hexagon-matt-white-23x26mm-mosaic-tile.html
Anyway, the best solution is to rip out and start again.
You need to describe what is the floor height outside the shower (is the whole floor tiled in this mosaic or is it a different tile)
Photos of the whole room would be beneficial for a distance evaluation to help solve the problem.
Reply to Advice Needed - Please be gentle! in the Tanking and Wetrooms area at TilersForums.com
