The Beast
  • Thread starter Thread starter Mike ramsdale
  • Start date Start date
  • Featured
The Hz rating of American machinery is slightly different to UK, but fundamentally there's no reason you can't just chop off the plug and use a transformer.
You can also buy UK 240v to US 120v step down transformers but you'd need a pretty powerful one to stop the RCD's tripping on the consumer unit.
These days with the poor Sterling/Dollar rate, shipping cost, import duty and VAT it's probably no longer worthwhile. There was a time that stuff was effectively half price, when it was (years ago) I bought a compound mitre saw from the US for less than half the cost in the UK.
Does anyone know if you can somehow use American tools in the UK? this cutter looks the bollox and half price of the Dewalt on ebay but I can't find a UK version anywhere. the one step set up is a time saver and its way more versatile than the dewalt with the sliding head etc.......
https://www.google.co.uk/url?sa=t&s...RMxxQN6WnMJReW68Q&sig2=O0ic6-RS7VXxwVfeS-tDAA
I emailed a seller on ebay asking how much postage would be and it was about 200 quid I fancied one my self till then
I'm using mine at the moment on a carrera marble job got sick of the sigma 10m having to flip the tile on the face and make a little nick before turning it back over to make the cut or it blows the edge of the back end as u pass it through I'd that makes and sense
Genuinely interested..what exactly does it do an angle grinder with a decent blade in it can't?
Very smooth edge to cuts.
20mm limestone with an angle grinder and top quality blade = maybe 2or3 mins per cut.
Dewalt, or other decent saw = 30 secs.
Minutes turn to hours, hours turn to days, days turn to lost profits.
Erm,typically 😉 i find it quicker and more accurate with a grinder on stone .
The house i did recently was around 3/4 foot out of square front to back .
Every room (7 rooms in total) was twisted badly , it would of taken me longer to cut with my machine , i just measured, marked and cut away .
Oh and every blooody skirting was on in every room , and not one wall or skirting straight 🙁
Ps i once saw a thread or post on here years ago saying you should not use wet cutters on stone as you can't lay it wet?
Clearly with "bespoke" cuts a grinder is going to be easier but with repetitive cuts doesn't the saw win? Horses for courses isn't it?
You're right Craig but thankfully most of my floors have no skirts in place so i can rip-cut everything.
As for fixing wet, I'll take the argument on!
Wet through obviously not a good idea, but damp is fine. Any moisture should be locked up with the adhesive setting, any moisture in the stone body will dry and depending on what/how you're sealing you might need to wait until dry.
Last job i used universeal rapid all in one which can be used on damp stone.
I'd rather fix damp stone into adhesive than dusty stone.
Not sure paul if im honest,i cut everything with the grinder on this job, but i think its each to his own , i have quite a steady hand(apart from mondays 🙂 ) so i find it quicker than faffing about with a big machine, lining it up (not every cut is going to be perfectly strsight, how many rooms are perfectly square 😡)
Dave 😉
Im not arguing about wet cutters, needless to say i didn't listen to the advice :tearsofjoy:as i thought it was a bit blooody stupid advice imo , i do still use a wet cutter when i can be bothered to get it out .
Your points about drying when laid and it won't be dusty were my thoughts , so i carried on as normal :innocent:
One thing with wet cutters from personal experience. Make hell of a mess but I do use a permanent bridge saw .
its horses for courses as some wise man said 😉
All wet cutters are dirty , spraying water etc, but grinders are dusty , dust everywhere , wet cutters win it for me on being cleaner, but still mucky though 🙂
Just for balance - i confess to using my grinder on easily 9 out of 10 jobs. It's quicker.
(unless you've loads of rip cuts in limestone to make) 😛
Personally I go for the wetcutter 9 out of 10 times I just can't get a clean enough cut with a grinder I bought the festool one with the dust extractor port and had in my had I'd use that but it never comes out the box
I use a makita variable speed with marcrist akkumax blades and a very light hand. I can get a very clean cut on most tiles.
I find the trick is to run lightly down the glaze using a straight edge, then start to cut slightly past the first cut, this helps so the glaze pinging.
Well no body's really convinced me this is something I NEED to have, infact I'm convinced I really don't need one at all..
They're a nice tool to have and a must-have if you're fixing lots of stone. (in my opinion)
@Andystiletiling
Erm, I'm sure, yes yes you did , you borrowed my wet cutter the other week to cut slate skirts 😉
Or is it, "I don't need one, Craig has one" kinda thing 🙂🙂
You HAD to mention that didn't ya!! 🙂
Must admit it did give a nice exposed edge on the skirts..
Still for once in every blue moon, then yes mate...you have one 😉
Grinder for porc and ceramics.
Wet rubi for stone and envelope cuts in wet room.
There is no way you could cut Kathmandu slate from porcelanosa with grinder - just chips away no matter how careful u are.
I have a small wet cutter which I have perviously used on most stone jobs upto 600x300 12mm, which cuts great but since I have been using the grinder more, I'm gonna go with that next time.
When I did the 900x600 20mm limestone job I used a 9 inch grinder and that was great for it. Saves manouvering a massive tile through a wet cutter
The Beast
Tags Tags
None
Mike ramsdale,
Dumbo,
Mike ramsdale,
Dumbo,
