olly330
Long story, but the some of the floor tiles that have been laid are from a different batch, this was a mistake from the supplier (big national company) as they should ensure all tiles are from the same batch.
The supplier has accepted they messed up mixing the batch of floor tiles and will be sending out a whole new batch of floor tiles as well as adhesive as they cannot track down any tiles from the same batch.
The supplier recommended laying the new tiles ontop of the ones that have just gone down, does this sound ok?
The tiles that have just been laid were on a no more ply substrate that was well screwed down, so I know I will have a height issue (6mm no more ply + 8mm tiles + 8mm tiles ). Would this height stand out too much?
Also, I don’t like the look of floor tiles that butt up to wall tiles but don’t want the last row of wall tiles to be ripped out as that could cause further damage up the wall tiles.
Should a gap of around 3mm be left around the edges of the floor which would be filled with grout or clear Silicon? Or should the tiles floor tiles be run tight to the wall tiles and a clear Silicon used?
Or what other way would be best to deal with this, are some sort of edging trim for floor/wall available?
Thanks for the help
Thanks for the help
