Currently reading:
Electric Cutter...
Discuss Electric Cutter... in the Tiling Tools area at TilersForums.com.
Spare Tool
I've always used a flat bed electric cutter for cuts that need it or tiles that need it, always with water. I hear a lot of people saying they don't use a wet cutter. Do some of you use a grinder for all cuts that need it? Even on porcelain?
Just recently switched over to a grinder with an ats blade in it, always been like yourself and used a wetsaw for L cuts etc. Sigma for any straight cuts.
Been using the grinder since Jan and takes some practice but can now split a pencil line with it and finish is as good as wet cut.. The vitrex been taking up unnecessary room in my van, infact I think tomorrow will finally put her in the shed :)
Got a link to the blade you use?
I'm pretty good with the grinder from doing metal work as a hobby. The only time I use grinder for tiling is the 9 inch grinder when using really thick and large stone floor tiles. Which cut like butter. Always found the grinder Rips up the edge of porcelain and doesn't feel right.. How's the dust?
Spare Tool
Porcelain Continuous Rim Diamond Blade | ATS Diamond Tools
Takes about a month to wear in properly.. At the moment using it in a Bosch 240 grinder but am so convinced this is the way to go I'm soon gonna get a good quality battery grinder to avoid running extensions outside etc.
Wouldn't say dust was a major problem, just cut with the wind on your back.. been told a way of flipping guard over so dust fires away from you ;) but haven't got to grips with that one yet, as I said new to this method myself but will fine tune over time..
When you only need to make around 6 or so cuts in a bathroom, why bother with a wet saw?
I use this mainly for bathroom work. (nipping outside to make the cut of course!)
The blade is so thin and the grinder so smooth in operation, the cuts are superb.
Just Rizzle
I use exactly the same brush less makita and markist850 blade also use it as a polisher brill bit of kit
Wishiwasatoptiler
1,118
Northeast
Has been years since I have used my wet wheel...4 1/2" grinder with good quality blade all day long... Once you get used to it ... So much time saved with equal results :confused:
I used my grinder today. Had wet saw in the room but no water in it. I had bought a Mar cist blade for it but also got a ats Dimon rim blade. Tried that all day on cermic, tip top. Loads of cuts and it coped to bother. Think I'll keep the wet saw in the van bit grinder all the way as much as poosible anyway... ;)
Reply to Electric Cutter... in the Tiling Tools area at TilersForums.com
Hi all. Just wanting some advice and wondering what the pros in here are using nowadays for cutting large format porc? Ive been relatively lucky up until recently and been able to cut most of...
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
You're browsing the Tiling Tools category on TilersForums.com. Find the correct trowels to use with which type of tiling. Find advice on lash clips and levelling systems and more.
