Currently reading:
Hardibacker Tanking Question
Discuss Hardibacker Tanking Question in the Tanking and Wetrooms area at TilersForums.com.
Is this just a bathroom with a standard shower, I wouldn't tank it, I only tank in walk in showers really unless a client/ builder specifies this then I'll do it.........if your using Hardi backer boards, mastic sealing everywhere before and after tiling and allowing all material to cure for at least a week what's the need to tank??......
Hardibacker isn't waterproof! If it gets wet (depending on shower usage and tiling etc) then it transfers water to the ply it's fastened to. Then all hell can break loose.
Cement boards have NO place in wet areas when there are products like Wedi and Kerdi out there.
MW Smith Ceramics
I have tiled onto many backer boards over many years in bathrooms and never had a come back...........
MW Smith Ceramics
:grimacing:I do use wedi also, just prepared a bathroom in wedi before tiling as client insisted, so am I the only fixer that's done this then......am I on my own here ?.......I've done many hotels - travelodges , premier inns where we have tiles directly onto plasterboard in the shower areas with no tanking or mastic sealing prior to fixing, now that's asking for trouble I admit but all us lads were doing the same in all rooms for years.............this was the prep spec before tilin
MW Smith Ceramics
Yes I think what your saying is the right thing to do to be totally sure of waterproofing there buddy......I have tanked many bathrooms but also not tanked many with no probs.......what about all the contract jobs you must have done tiling shower rooms directly onto plaster over the years when tanking wasn't specified by builders......done it for many tiling contractors with no problems........but I agree tanking defo the way to go - ( better to be safe than sorry )
P
p4ulo
Never done any that I haven't tanked.....I've had to fix several jobs where tbh it wasn't failure due to tanking ( flexing shower tray, cracked grout, missing sealant) so I always insist on it and get it paid for every time.....That being said, I'm not a big trader so never work on new-builds / for builders....!
Hi Impish.......
Do you tank, wedi or Kerdi every shower area you tile then mate?.....
I do mate. it's all domestic work and normally top end stuff so the cost is easily lost. if you've not already guessed, I've a personal hatred of cement board. Particularly hb. Mainly after ripping out plenty of stinking wet mouldy wet rooms all with hb which hadn't broken down but had allowed water to do it's thing to everything that wasn't hb.
Tanking kits are about £50 and cover enough to do a shower enclosure or above a bath. So maybe £100 supplied and fitted? I have tiled for years with only tanking wet rooms, but these days i do suggest tanking to customers and explain it all to them, then they have the choice. Depends on the job, if it's a cheap bottom end job, there probably not gonna go for it but any job to a decent standard people tend to go for it. Trying to convince a builder to go with it is a different story!
What do you class as the ideal product to board the walls in a shower area, and the floor
MW Smith Ceramics
:flushed:
hahaha!......yeah they look at you gone out!!!!
MW Smith Ceramics
And everyone else, forgot names sorry :thumbsup:
m
I have no local supplier who does Wedi type boards, all have to be sourced through the net...
me neither I get Marmox 10mm boards online from ( the tile experience ) works out to roughly £7.50 for a 1250x 600 sheet including vat......I get all my Schluter from there too ( cheapest I can find it anywhere @ £8 per metre and my local supplier is selling it at £14!!!!!!.....money grabbing git!!!!......that's daylight robbery!......
MW Smith Ceramics
thanksfor your replies.
didnt want to tank due to possibility of weight issues once i decide on the tiles, plus the cost as most tanking kits seem to be not large enough to cover the area.
is everbuild aqueseal any good. its only £43 for 7.5m2?
I've never used that one so couldn't say, but I always use Norcross wet seal tanking kit @ £33 and you get around 5 metres ...but I would say if your using heavy tiles go with wedi or Marmox 10 or 12mm glued and mechanically fixed......
Reply to Hardibacker Tanking Question in the Tanking and Wetrooms area at TilersForums.com
  • Sticky
