Discuss Metal Capped Mosaic in the Australia Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
macten
Regular wet saw blade is fine. Avoid slithers or the metal caps will come away from the ceramic and you'll need to glue 'em back on!
macten
Also (depending on the finish on the mosaics) check your grout on an off cut - some scratch real easy, Mapei's fine grout was too scratchy but their super fine grout was okay.
Well if they're meshed backed, wet cutter wouldn't be advisable, it'll wreck the backing.
Last one I did I used a thin metal blade on a grinder.
macten
I've done 4 last year on mesh - they're fine. Another tip is the blade might burr the edge so after the cut just angle it into the blade to take it off
Q
Qwerty
Here is the last job I did using metal capped mosaics. Mapeiglitter grout which tried its hardest to scratch the metal! I had to cut the metal on the shower tray plinth, killed my ATS turbo blade by the end, but was worth it
macten
If you end up having to cut slithers the metal caps will come off no matter what you cut them with - most are spot glued in the middle.
Lovely bathroom that Plan tec.
This is a kitchen I did last year
Reply to Metal Capped Mosaic in the Australia Tiling Forum area at TilersForums.com
Lowpaul22
