Discuss Grout Or Sealant in the Australia Tiling Forum area at TilersForums.com.
P
Phil164
Hi
I recently moved into a new house where the grout needed replacing around 1-2 tiles in the bathroom. I scraped out the old grout and put new grout on top. After about 2 months that new grout is now cracking. Since nothing else has cracked I assume it's not because of movement so could it be the mix I made was too runny? I used waterproof unibond grout for bathrooms.
Now my weekend will be taken up with scraping out this grout, maybe pretty easy given its cracked :) but I was thinking of using sealant to replace it- it's white and at least that won't crack.
Is this a good idea or how should I go about avoiding future cracks!
Thanks for your help
Phil
U
Unused Account 1
If the tiles is fixed properly ,grout again you only need smallest amount make it thickish and make sure to push it in the joint getting all the air out ,if it cracks again you know
P
p4ulo
Where is this grout?
If it is up against the bath edge, or in a corner against another wall, you should use sealant, because any movement can cause the grout to crack.
Don't use sealant as a general grout.....if you do don't say on here!!
Mr Tiler
Any internal corner needs to be sealed! If its on the wall nock up a thick mix and push it rite into the joints with the flexi version of your grout whatever it is, theres usually a flexi version... if tiles havnt fell off the wall whilst scraping at the joints then tiles should be sound.
P
Phil164
It's not up against a bath (there isn't one) or wall. It's on the floor and around the shower drain- which is on the floor, I've no separate tub.
I've no idea how the tiles were fixed initially because I only just moved in. But my fix I did a couple of months ago now looks worse than what I tried to fix in the first place.
But it sounds like I need a thick mix to prevent future cracking. I'll find a flex version of the showerproof grout too. I used unibond before and have read good stuff about mapei, so I guess either will be fine.
Thanks guys
P
Phil164
Sure, here are some pictures - Sunday morning is DIY morning :)
around the drain there was cracked grout so i removed the metal insert (held in place in the screw holes) then the grout came off easily. One of the close up pictures shows there appears to be some sort of membrane under the tiles but also some gaps, should i push some grout in there first to fill the gap? Should any of this 'tray' be sealed first?
The other pictures are of the other areas where there was cracked grout, should be straight forward to just push thick grout into.
Advice much appreciated!
Phil
2015-09-20 11.33.20.jpg 2015-09-20 11.33.08.jpg 2015-09-20 11.31.50.jpg 2015-09-20 11.22.25.jpg 2015-09-20 11.22.18.jpg 2015-09-20 11.22.11.jpg
Reply to Grout Or Sealant in the Australia Tiling Forum area at TilersForums.com
