Discuss Tiling Standards (BS 5385) | British Wall and Floor Tiling Standards - IN FULL in the UK Tiling Forum area at TilersForums.com.
R
Rizzle from the Portizzle
well let me get this right bs again and again lower standards and these are the ones you follow .i wonder just how many hand shakes it takes to get your doggy tiles approved and all other rubbish that they spec to minumum standard when there not cutting and pasting . bs standard who right them might be worth a look and who do they work for .the answers are out there
Wishiwasatoptiler
1,108
Northeast
This makes for intresting reading, so not wanting to name or shame, and this may not be the section for it but which tile manufactures should I be wary of.
U
Unused Account 1
Tiled the whole downstairs of a new build ,floating floor,the customer supplied the adhesive with guarentee in writing that it would not crack or lift from the company ,forget wich adhesive a few years ago ,perfect for the tiler is covered
AliGage
Subscribed
1,138
Peterborough, England
I've never found any tiles so far out if tolerance like that.
Some cheap cheap tiles have maybe been upto 3mm. I'd just use these for cuts.
With most porcelain being rectified these days it's rare to have them so far out of whack IMO.
Tile Shop
Tiles have to conform to BS EN 14411. 82 pages but this is a snippet that will cover (at a guess) about 95% of all ceramics available today. There will be standards for Natural stone too... I will need to try and find these
Extruded ceramics:
Tolerance from the average size = +2% to a maximum of +4mm
Tolerance for thicknes = 10%
Dust Pressed ceramics: (which most ceramics and porcelain are these days)
Tolerance from the average size (for tiles between 70 and 150mm) = +0.9mm
Tolerance from the average size (for tiles 150mm or greater) = +0.6% to a maximium of 2mm
Tolerance for thickness = +/- 5% to a maximimun of 0.5mm
(This also applies to rectified.... don't be fooled)
This shouldn't be confused with nominal sizing...... This is just a guide to the size contained in the box. The average size of the tiles contained must be within -10mm (based on the example given in BS EN14411 but I will need to dig deeper for the exact numbers).
Take Johnsons as an example. They make it clear on the box and show the nominal size as 200x100 (which is what most suppliers will advertise them as) but the actual working size may be 197x97 but credit to them, they also mark this on the packs. Most factories only provide the nominal size, so what you actually buy may be a very slightly different size, but still within the nominal sizing tolerance.
Its a bugger when we get a customer, orders some tiles to match some existing tiles which are 200x100, see a tile advertised at 200x100, that then gets delivered 3mm smaller each way. One of the reasons that samples are advised and that tiles shouldn't just be ordered on a whim.
Another tolerance fact for you. Did you know that if you buy a tile that has a slight manufacturing fault, like pits in the glazes or a printing error, as long as the fault only covers no more than 5% of the face, THAT IS ACCEPTABLE according to BS???? guess what else BS stands for!
Its way too early for this.... I need a coffee and 10 minutes brain rest....... "Tolerance"...... hate that word. Just another wall to hide behind.
Tile Shop
Wanna hear another absolute stinker on this??? Based on the examples given in EN14411..... again.
Example.... A range of tiles which for examples sake is called Asbestos Bog.... available in 3 colours, Black, White and Poo Brown (3 colours associated with an asbestos bog... see what I did there? white pan, black cistern, and...... nevermind!)
The nominal size is 600x300. The customer has worked out a design for a single wall based on this advertised (and legally acceptable) size.
Due to the manufucturing process and timings of the batches, the Black is 599x299. The White is 595x296. The Poo Brown is 600x295.
These tiles are within nominal sizing.
These tiles are within tolerance because tolerance is only forced upon a single tile design from a single batch. Technically, all 3 tiles are different so the tolerance doesn't apply between them.
Tragically, these tiles conform to British and European Standards.
Bummer ay!
Dan
Admin
1,318
Staffordshire, UK
Due to the manufucturing process and timings of the batches, the Black is 599x299. The White is 596x296. The Poo Brown is 600x295.
Bummer ay!
That does suck actually.
It's when we tilers tile two colours (doesn't get done much like it used to, with a border tile etc) you end up needing to judge the spacer size well with a few stacks of tiles.
Tile Shop
We've raised a similar situation with a manufacturer once before... this is what they threw back at us. Thinking it was complete boll***s we investigated further. A day later we were scracthing ours heads thinking "they're right and we can do naff all about it".
We had to let common sense prevail and despite the tiles conforming, we collected the tiles from the customer and offered an alternative and a refund for the inconvenience. Never sold the 2 colours together again, and weirdly enough, never ordered from that factory again.
ANYONE who uses Original Style tiles can tell u what a pain that is!
Even tho they're from same design and are meant to work together, they're not the same size in relation to each other.
Prime example, this floor! Most joints are two mm but the joints around the White are one mm. And to make it even more frustrating, even tho the white triangles can be bought, u can't use them because they come up in a different colour so they have to be cut from whole tiles. Which increases wastage because they don't always cut cleanly.
View media item 12172
Tile Shop
I had to do a 1.5sqm showroom display of a pretty complex victorian pattern once. I know i'm no tiler but that bugger took me 4 days to get it right. It was a mix of about 12 to 15 tiles, squares, triangles, rectangles, all different sizes.
I think because they are pre-cut and used for many differents designs, its never going to be 100% perfect from one style to the next. Mine ended up having joints from 2mm down to 0.5mm. On tiles that are as small as 35x35mm, thats a mahoosive difference. But once grouted and taking the magnifying glass away, looked like a pro had done it :) (not usually one to blow my own trumpet.... but it is long enough, and working with those, I can be forgiven for doing so.)
Seriously though, I don't envy the tiler who turns up at a customers house, and after measuring up the 30 metre floor and is then told "I want a victorian pattern"..... I can imagine the heartache!
Reply to Tiling Standards (BS 5385) | British Wall and Floor Tiling Standards - IN FULL in the UK Tiling Forum area at TilersForums.com
