Tile Tracker or Wood Batons
Wishiwasatoptiler
Hi All
looking at purchasing tile tracker, but would like thoughts on whether people think its worth it are not and also which set is the most useful.
I'll have a look at these, I have a couple of props for batons that slide up and down similar to those on your link but ajustment is a bit of chew.
This is the type I have, is the rubi similar
Just out of interest, what size timber baton do people use, I've struggled to get decent straight stuff.
Cheers
Cheers
They look like the rubi ones.
I used to use 2"x1" timber. Sometimes still do. But generally it's batten stands and a straight edge/level or I've got two lengths (1 &2m long) of 20mm boxed steel
I set my laser up and do the bottom row of cuts and then go up, I used to hate it the first few times but now I find it very helpful 🙂
Wood batons imo, I go woodyard and get half an 8x4ft sheet of 12mm wpb sliced down into 2inch x 4ft lengths on their flatbed saw...perfectly flat, that usually lasts me about 6months, each to their own system but datum line and staff and batons works for me..
U old fart! Haha 😀
Haha..till someone shows me a better method of marking a room up and landing a full tile over a window or door to the mill and impossible to loose your groutlines I'm sticking with it mate 🙂
Thanks for all the tips, seems there's no need to splash out on the tile tracker, think I'll give all ago and see what works for me best. I had thought about boxed steel too, but like the idea of picking up the wickes gear.
Cheers
Use old levels or one of my screed rules for heavy tiles...not that I've done any screeding for a number of years.
I've got Tiletrackers, but then I'm more of a tool junkie than a proper tiler!!
I've got about 6 different lengths, and I carry them around in a ski-bag that I got for peanuts from Ebay. Love the system, really easy to adjust once you get it in roughly the right place, and very flexible.
don't buy new though, hunt ebay for second handers.....(which begs the question, if its that good, why are people selling it???) lol.
If you;re attaching your batons to brick wall , platsered...do u use screws and rawlplugs? does it ow get tricky to get perfectly level?
If you're gonna use batons,
Best thing to do Steve is draw you're level line first, then using oboe nails
(Masonry nails) nail you're baton to brick walls.
U'll find it a lot easier than using screws!
Any straight bit of timber works for me and a laser level cheap (well, timber is 🙂), easy, and accurate.
Wishiwasatoptiler,
AliGage,
Wishiwasatoptiler,
AliGage,
