Discuss Small Support Props in the Australia Tiling Forum area at TilersForums.com.
***tony***
428
Hi all, does anyone know where I can get some small support props for doing window reveals, fed up using bits of timber.
Also, is it possible to change my password to one I can remember?
Big thanks.
Dave
Subscribed
1,000,000
Co.Durham
Big thanks.
Admin can change your password if you can't remember it , or go to settings and use the change password feature >>> http://www.tilersforums.com/account/security
P
p4ulo
I've been thinking about getting some of the exact same thing.
Last two windows I've done I've used my extendable crutches (ruptured ACL skiing!) to great results, but I'm fairly sure a client would be more impressed with something purpose built.....(plus, it made getting about difficult once I'd used both crutches!!)
I'll probs make adjustable wooden ones, two battens, pre-drilled holes and a couple of bolts.....
***tony***
428
At last, got round to making window props. Used my old plasterboard props, haven't used them for years. Took them apart & cut them to size, refitted them, took about an hour to do. Size closed is 27 in size extended to max is 61 in.;)
Reply to Small Support Props in the Australia Tiling Forum area at TilersForums.com
Hi All - I am searching for Todagres Aral Beige Pulido tile (large format - 32"x32"/ 120cm x...
Landsteph
L
  • Sticky
