Discuss Adheasive Advice for dry stacked stone in wet enviroment. in the Canada Tile Advice area at TilersForums.com.
P
Pandemonium001
The Customer (wife) has requested a wet room down stairs.
house is new build so shower area stud partition walls have been reinforced, plaster replaced with green sheets, primed and tanked with mapie tape and WPS kit.
The shower is over head high flow low pressure, Tiles she has bought are dry stacked Quartzine Mozaic backed with mesh with little or no gap to grout,thats the biggest problem, they will probably be sealed with LTP Mattstone.
Area is 5m/Sq vertical
Any recomendations?
initially i thought of BAL easy poxy, which is no longer available, Mapie Kera poxy is not flexible enough. Would BAL Max Flex Fibre be O.K,
Floor:
concrete base raised with 2"x2", 18mm chip, 10mm marine ply screwed 100x100 and glued.
will be tanked using Aquadry's membrane.
Tiles 600x600 porcelain approx 5.5m/sq
Recommendations? I thought Bal Fast Flex grouted with epoxy or Mapie Keraquick with latex grouted with epoxy.
The room will hardly be used and if it will mostly for just the bath.
My prefferred Brands are BAL and Mapie
Any advise is welcome, Thanks.
Andy Allen
1,318
Gloucester
got a link for the tiles......are they the type of tiles that are only for feature walls...like split faced tiles..?
P
Pandemonium001
It wont let me post the url.
tile giant oyster split face mozaic.
and yes I know it states not suitable for direct water contact, but cant return them now.
Thats my concern with how water resistant the adheasive is.
thanks
White Room
As it states water resistant, water won't damage the adhesive but will allow moisture to reach the background depending how much usage the shower gets...
Andy Allen
1,318
Gloucester
deffo wouldn't use them in a wetroom, there going to be nigh on impossible to grout and will be a breeding ground for bacteria ...
P
Pandemonium001
Thanks That makes sense, water wont affect its mechanical grip, but will not be water "proof"
So I am thinking Bal Max flex fibre for walls in white 0-6mm bed
Bal single part fast flex for floor 4-10mm bed with cement grout mixed with admix GT1
any one see any issues with these?
P
Pandemonium001
Hi Andy, I know the grouting issues, thats why i was concerned about adheasive longevity.
The shower will hardly be used, twice a month at the most, its a very well heated room so i am happy any moisture will dry of fast.
Bacteria, well she can get the stone cleaner and tooth brush out! :lol:
623
Leeds
Why don't we grow some, and tell the Mrs these tiles aren't going in the shower??
might sound a bit harsh, but no point fannying around..
Reply to Adheasive Advice for dry stacked stone in wet enviroment. in the Canada Tile Advice area at TilersForums.com
