Discuss ats bullnose tool in the Canada Tile Advice area at TilersForums.com.
johnryan
hello all, just thought i'd put a post up about the bullnose tool for a grinder that i got from ats recently.
after first rate advice from alan, i got the starter set they recommend, and here's a few pics (unfortunately phone doesn't take very good pics) of the first time i used them
the steps there, were just made up from leftovers, and done as an afterthought, but look really good and the pic doesn't do them justice really. also did another marble bathroom, but pics are too blurry to see anything. the bullnose tool and the dry polishing pads made easy work of both the trav and the marble. the detailed advice given from alan was spot on and the money definitely well spent. just wish i'd known about them before now. and once again for alan, a big thanks for all the help. cheers mate.
john
johnryan
no problem alan. need to give you a call tomorrow to get some hole cutters, most of my old ones just about ready for the scrap heap now. was wondering if you'd heard any more about a vacuum fitting for the makita too. just bought a wet and dry vac so would be very handy if one became available. need a good marble blade for my grinder too, so any advice would be greatly appreciated. currently using a rubi cpa blade on my wet cutter, but was hoping you may have something better that i can use on my grinder.
johnryan
yes that's exactly what i was hoping you may be able to get :thumbsup:. would be great if one will fit on mine. will call in the am for my drills and blades. cheers.
john
johnryan
and found this from the photos of the other bathroom. didn't come out so blurry as the others;
polishing pads brought the marble up very nicely
Concrete guy
john
Is the dust extraction for when you're cutting rather than polishing/grinding?
johnryan
yes mostly, i've got a job coming up in a couple of weeks, in regents street so all cutting will have to be done inside, so anything that can help with dust is a bonus. will have a wet cutter there, but i use my grinder a lot too, so the dust will be a big problem for me . also lots of profiling, though that doesn't seem to be too much of a problem as the dust levels are pretty low doing that.
Reply to ats bullnose tool in the Canada Tile Advice area at TilersForums.com
