Discuss Threshold bars in the Canada Tile Advice area at TilersForums.com.
Turkish
Hello
Could anyone please advise me as to whether a carpet to tile aluminium bar exists that can take up a height of 34mm?? That is the height of the top surface of my tiles in my bathroom from the floorboards in the adjoining room where I`m having a new carpet laid. Carpet supplier said they didn`t stock anything to take that height difference.
Any help would be much appreciated
Q
Qwerty
Don't know any that's greater than 22mm.
Double up on underlay?
Ali is right. I thought the Schluter Reno V would cover your needs, but only 20mm I'm afraid. Does it have to be metal or will an oak threshold be suitable?
Ian
An overlay of 12mm ply in the room to be carpeted could be a solution. Is it a big room?
AliGage
Subscribed
1,138
Peterborough, England
Think it will depend on the quality of carpet being fitted too. Some cheaper ones woukd wear and could highlight sharp differentials like ramps.
If you want to eliminate the step the Bri's option works with 12mm pky. Should bring you about level.
Mr Tiler
I'd go for either a wooden threshold or a wooden ramp under the carpet
exactly what I would of suggested I don't this with my bathroom floor as there was a 19mm height difference so put some 8mm ply under the carpet and fixed a standard doorstrip over that looks sound and better than a lip in the doorway.
thought I may get slated for that suggestion though so kept it to meself lmao
peteablard
1,058
Cheshire
I ramp floors up and down in loads of commercial environments to eliminate trip hazards between different floor levels. Quite often it's done using rapid set. The problem with raising the whole room is you then transfer a height difference to another doorway
Turkish
After much research on the internet I think I`ve found a suitable threshold but if it doesn`t work then I`ll go for the ramp option
Thanks to everyone for your help much appreciated!!
Reply to Threshold bars in the Canada Tile Advice area at TilersForums.com
