here you go.. lets hear it lol...
Mr Tiler
Over all first impressions from the pics it looks ok.
There are some basic errors like setting out bond to window (left side).
Some bad cuts to the ceiling and some lippage is evident , but over all from the pics it looks to be ok.
I do take it you are DIY. So a good effort.
its been finished since... my cousin doesup houses for a guy and he heard I was into tiling so he gave me a bathroom to tile lol.
I didn't measure up and the tiles that were supplied wasn't sufficient. I was running low on tiles and was told to conserve the tiles as best i could. my wet cutter kept snapping that cut so left it as is. cheers... u guys do know its mr t rite? lol
is your husband pleased with it ? not bad for a diy, the window needs a lot of work to improve it but i guess when you hang your curtains up they will cover up the bad setting out and no need for coat hooks just hang your bathrobes on the edges of the tiles that are sticking out
An l shape cut is not hard you can do one with just you're nibblers after scoring on your dry cutter with a wet cutter they are a piece of cake
No Ali checked floor for movement wont say none but very little had to put a few nails in the boards to secure tho... Glued n screwd hardi. Sealed with sylicone and scrim. Then tiled n grouted next day even tho I used rapid set. Cheers.
Cheers for the feedback mate.
Score them before hand! Why didnt I think of that cheers mate thats one for the books....
I spread the floor adhesive onto the floor boards.. And then fixed the hardi backer to the floor boards. The adhesive wasnt to level just to fill any voids... Is this not the correct method mate? Cheers
My cousin is a doctor and she knows I'm into first aid, but I wouldn't dream of diagnosing her patients knowing I would probably get things wrong!!!
Is it housing for the less able sighted?
Mr T Bag, is this one of the 'small' jobs you intend to take on? To be honest it really isn't an acceptable standard to be charging for is the simple answer. Regardless of the cut you couldn't do with the tools you had, there is a lot more wrong with the install.
Now this chap you did the work for may be happy with the job as i'm guessing his standards aren't very high if he didn't feel the need to alter the abortion that is the towel rail tails before it got tiled. So you may be happy with it and this customer might be happy it with it, but it is well below acceptable standards for most and another customer may well insist you rip out and start again at your cost. As for not having enough tiles, a good tiler could have spent an hour jigging the setting out which meant more cuts could have been used in other areas and I can see at least a whole row of tiles that don't need to be there once the bath is installed... which btw is always better to be installed before tiling.
Back on to the plumbing... who put those isolating valves on the shower tails? The plumber is going to have fun with that one when it comes to putting the shower valve on. No need for those to have been cut so close to the walls. Options are now limited.
F- Must try harder
My goodness! I didn't even realise they were the shower feeds, I assumed they were the basin feeds for a vanity type unit. Oh dear.
In my honest opinion Mr Tea Bag, this is about what I would expect from a below average to average DIY attempt.
I appreciate there is a mixed opinion of your abilities and ethics on here, and whilst I cannot knock your enthusiasm, I can say that your work is not of a chargeable standard. I know a lot of people have had a lot to say in various threads, and I for one have sat on the fence until I saw your work. Now I have seen it and had my say.
I wish you all the very best in the future.
F- Must try harder
well I was thinking so but im just thinkin about going back to the factories as I don't want to be labled a cowboy and will never get myself in with a pro. I raised the question about the shower feeds as I knew it would be a problem but was told to crack on and they would sort it. all inlet pipes accept the rail pipes were changed before boarding the floor but I don't even know why he didn't change the rail pipes. but again was told to crack on and it would get sorted. yes they were very happy with my work and I was until I came on here tbh. in regards to the pipes and bath you can only do what you can I was told to do it so I done it. I raised my issue with them. they were happy so I just got on with it.
thank you... below average to average d.i.y is a bit harsh tho mate. you say its not acceptable to charge for this work which i understand mate. unchargeable it is then... but i can already see im being slated on this thread for it being me. comments wasn't so harsh when i firs posted and i should of left telling people who i am maybe comments would of been a little harsh... not at you plan tec
I've resisted and resisted and simple can't any longer.
Mr T although your enthusiasm and want to provide for your family is incredibly admirable i think you are completely blinkerd or maybe just ignorant.
The rest of this post may appear harsh but if you really want to make a profession out of tiling please look at it as constructive criticism.
The tiling is poor. It is certainly not chargeable work by any means. For a first effort well done. But this is somebody's home! And more so someone's hard earned cash.
There is clear signs of lippage. The cuts to the top of the room are awful. Grout has been washed but not profiled. There's an over spill of grout to the side of some joints that exaggerate the size. Setting out issues. Some cuts are nasty. Shower pipework has been mentioned.
I don't know how you can set out your tiling without knowing what tray is going to be installed.
Many members have you a lot of advice and really tried to help you but it looks like its falling on deaf ears. Neal even took you on for a day to give you some advice. You've been pointed in the right directions and you've ignored it all.
I can see you being the sort of member that takes on a job, comes on here to get the info on how to do it and then goes and has a crack at it. This is not something i can condone or encourage so i won't be taking any further part. You definitely shouldn't be experimenting in peoples homes and you can give that same advice to your builder friend.
One last thing i have great issue with and i tried being discrete with pulling you up on it but now ill be blunt. "Hardie glued and screwed"
I can't stand liars and i believe you are here. Im almost confident enough to wager on this that there is no hardie under those tiles. I have about 4 reasons as to why i think this but im not going to disclose.
I do however hope you make the right decisions and keep the enthusiasm from here on out. But taking money for that standard of work is something you should not be doing.
ouch ! but fair, they are big jobs for your first try's cant you just stick to splasbacks and small floors until you get the skills i have only been doing it just a little under two years and i have only just started doing these type of jobs this year, Don't loose faith take aboard the advice you are being given and i am sure it will work out, take loads of time at home with cheap tiles practising your cuts always make sure they are tight, use the correct trowel to help with lippage and also practise your siliconing as this can spoil the whole job even if the tiles are perfect, also have i bit more respect for the other tilers on here as they will help you a great deal if you have the right attitude good luck Paul.
also take time on your setting out, even if it takes a couple of hours looks like on the floor you have said to yourself i am starting with a full tile on the left and that's that because there is a 30mm cut on the right
ali ive had good sound advice and a lot of the helpful comments have been been from you mate... and it really has been taken on board. I do respect and and hate the fact that some of the guys on here have come to the conlucion that I am ignorant and the helpful advice has fallen on deaf ears.... cuz it really hasn't. you are the pros end of and I wouldn't think I know any better than any of you on here but some of you come across to me to feel that if you havnt been tiling for years and years you cant be any good. ive been learning tiling for not very long at all and that bathroom is a very good attempt and I know it has faults and I took about half an hour setting out and came to the conclusion there would be bigger cuts all around the room if I did it the way I did the window is slightly off centre but that was so I had nice big cuts around the whole room. the floor wasn't full tile and go from there lol. I centred the doorway as there was nothing else to go from and the cuts on the rite don't even matter as there is a vanity unit going in along the whole side of the bathroom. its not a tray that's in there mate its a bath and yeh I would of had to know the spec but we measured before tiling and the bath fits in nice I advised its better to take the tile straight off the bath but he was happy for me to go ahead and tile. I just trying to defend myself respectfully and don't want arguments. Neale is a sound bloke and it was absolutely brilliant to work with him its a shame I couldn't do more as I learned a hell of a lot just in those few days with him. and to end the post you are going to eat those words in about ten mins ali lol. cheers and thanks for the advice over the last few months. its sad that ive came across as such an ignorant so and so and if you met me im sure you would see im not. cheers
I know its supposed to be staggers but didn't want little cuts of hardi on the boards so did it this way. ek0rad.jpg
the thing is mate I do respect the guys on here and there advice is going to be the best I can get. i don't know where the sudden feeling of disrespect has come from i have taken on board so much good advice from these professional tillers but it seemed like since the thread i made about self employment i have just been attacked by a few of the members for simply asking about self employment... if i was to go out and start taking paid work that is exactly the work i would be looking for small conservatories kitchen splash backs ect. i practise as much as possible and am now in the middle of doing my own bathroom so that's more practise for me. cheers
im only guessing but looking at the pic now id say to stop a dip forming in the cross of the join mate?
Tags Tags
aus usa
Mr Tiler,
Dan,
Mr Tiler,
Dan,
