Tiling on Asphalt
P
penno
What adhesive do you reccomend for tiling onto an asphalt floor with 60 x 30 tiles?
Prefer the Bal products, would you reccomend a flexi or would BAL CTF do the job just fine?
Ctf is a white adhesive and expensive as well....bal rapid set is fine for asphalt floors as it is polymodified to start with..but if you want that extra added flex then go for bal rapid set flexi.....bal ptb flexi is good for large format tiles but needs practice to work with it......
her's some info on those adhesives for you mat.........
BAL Rapidset
A cement-based, polymer modified, non-slip, rapid setting, water-resistant and frost-resistant adhesive suitable for fixing ceramic wall and floor tiles including fully vitrified and porcelain, ceramic mosaics, quarry tiles, dark natural stone, terrazzo and brick slips. Suitable for a variety of backgrounds/bases including concrete/brick/block walling, cement:sand rendering, gypsum plaster, plasterboard, fibre cement sheets, cement:sand screeds, ceramic/quarry tile/terrazzo/hard natural stone, vinyl tiles/sheet, mastic asphalt. BS EN 12004 C2FT Adhesive.
BAL Rapidset Flexible
A flexible, rapid-setting, non-slip, water-resistant and frost-resistant wall and floor tile adhesive especially suitable for fixing tiles, including fully vitrified and porcelain tiles to low porosity backgrounds and bases. Suitable for use on concrete/brick/block walling, cement:sand rendering, plaster, plasterboard, cement sheets, tile backer boards, concrete bases, cement:sand screeds, plywood overlay, ceramic/quarry tile/terrazzo/hard natural stone, vinyl tiles/sheet, mastic asphalt. BAL Rapidset Flexible white is especially ideal for fixing natural stone, slate, marble (including translucent marble) and travertine. Conforms to BS EN 12004, Type C, Class 2FT.
BAL PTB (Pourable Thick Bed) Flexible
A highly polymer modified, flexible, rapid-setting, water-resistant, frost-resistant floor tile adhesive, especially suitable for fixing tiles, including fully vitrified and porcelain tiles to low porosity backgrounds and bases. Sulphate-resistant, cement-based, pourable, thick-bed solid-bed floor tile adhesive suitable for fixing ceramic tiles, quarries, natural stone and terrazzo in interior and exterior situations. Its consistency makes it particularly suitable for fixing large tiles and those with profiled backs. Back-buttering is not necessary. Suitable for use on concrete, cement:sand screeds, ceramic/quarry tile/terrazzo/hard natural stone, plywood overlay, vinyl tiles/sheet, mastic asphalt. BS EN 12004 C2F Adhesive
BAL CTF 3
White, cement-based, polymer modified, non-slip, water-resistant and frost-resistant adhesive suitable for fixing ceramic wall and floor tiles, ceramic mosaics, quarry tiles, natural stone, terrazzo and brick slips. Suitable for a variety of backgrounds/bases including concrete/brick/block walling, cement:sand rendering, gypsum plaster, plasterboard, fibre cement sheets, cement:sand screeds, ceramic/quarry tile/terrazzo/hard natural stone, vinyl tiles/sheet, mastic asphalt.
Yeah but would i be ok using CTF on the Asphalt or is a flexi needed?
The job is for a certain family member i don't like too much but still want the job doing well
Basically was supposed to be on a job as we speak and purchased 80kg of CTF for it but job fell through. Bloke suddenly wanted brick pattern with a mosaic border that wasn't included in the price. Told me he would ply the floor with 18mm ply, turned up for the job and he said " didn't have time to ply but the boards are there for you to put down" didn't like the extra cost that was involved so i packed up.
So anyway 80kg of CTF sat in my van will it be ok on Asphalt or just stick with a rapidset? 🙂
Whilst we are on about Asphalt how long would you say it is before you could lay a tile onto a floor that has been freshly asphalted? I got a suprising answer off 2 asphalters today
as far as i know it will be as soon as its dry.....i bet they said within hrs........
Spot on Dave, spoke with my dad who was asphalting for briggs amasco for 30+ years and said the tilers used to basically follow them along, 1st tile went down on the fresh ashalt after 1hr 20 mins.
Tiling on Asphalt
penno,
DHTiling,
penno,
DHTiling,
