Discuss brick pattern advice in the UK Tiling Forum area at TilersForums.com.
John the tile
any done many jobs where brick pattern was specified?
1 centering it up. one row will have more than half a tile at the end of the wall but the next row up will have less than half a tile or even a thin peice which would then be every other row;.
2 also wondering about going round corners. would you the center the next wall out and have the end cuts touching the wall with larger end cuts on the wall you have just done.
3 The next walls tile end cuts are more than likely not going to mirror that of the tile end cuts of wall you have just done will it matter.
thanks for any help
faithhealer
I wouldn't centre the wall if you are left with silly cuts, walls look better when they 'wrap' around. This is where it looks like the tile has been cut to length and the off cut follows on round the corner. Not neceesary the off cut but you don't want long and short pieces meeting in the corner
R
Rav daniels
If u have to do it like that, make sure you start the next wall with the opposite of what u just finished with , so if you finish with your larger cut on the bottom row, make sure you end up with your smaller cut next to it, looks bad when you have 2 small cuts next to each other, so as faith healer says wrap around
Mike
thanks for any help
try make sure your walls are flat, they need to be good for brick bond. normal tiling will follow a poor wall but 'bricks' will kick out real bad
White Room
Check the tiles as well, if they have a slight bow in them your've got no chance to make it look right
John the tile
thanks folks.
i like the idea of startin on the window wall. can you explain. if i center the window ill more than likely end up with small cuts either side of the window whatever setting out i do..?
thanks
P
peckers
thanks folks.
thanks
you can move your start point a quatrer/third/or half a tile etc to see where is the best place to start and which is most pleasing on the eye!
remember that the tile above will finish with a different cut then the one below so check for this row too :thumbsup:
Davesax
With brick bond and small tiles you'll have to just minimise the size of the small cut at the window- and then check the cuts at the walls , you only have so many options . You half your possibilities with brick bond - it's difficult to say without measurements / tile size.
Cheers
Reply to brick pattern advice in the UK Tiling Forum area at TilersForums.com
