Am I Pushing It?
  • Thread starter Thread starter buddha1964
  • Start date Start date
  • Tags Tags
    usa
buddha1964
My Wife has decided on a feature wall in the bedroom in modular slate.
The substrate is plasterboard, A 6mm bed and 10mm tile just about takes me to the weight limit for plasterboard. Should I use a smaller bed say 3mm which will take the weight down to 31kg, would this be safer?
Don't want one of those 60 x 40 ...... on my head in the night lol!
I want to use Mapei Keraflex addy..Normally I would have just slapped it up so to speak but since finding this site it makes sense to ask.🙂
Either way SR, I wouldn't like to be border line above my bed :yikes:
What / how is the plasterboard fixed to, any chance of overboarding with hardie-backer, to be on the safe side ??
It's just plasterboard no skim, dry lined dot and dab, fixing hardibacker boards would be a bit of a nightmare..
Do you think she's trying to get rid of me:yikes:
Working on your calculations you would be within the limits. Not sure what you mean about 3mm adhesive though...you would be using a trowel size of about 8mm for that sort of tile and depending on the calibration of the slate and your requirements you would go above that.
I would go for a tile backer board personally :thumbsup:
The 3mm calculation is for a 3mm solid bed..
I would seriously think about the backerboard method....sleep well at night and you will also wake up in the morning without a chunk or slate in your forehead. :thumbsup:
You will struggle to get a solid bed with 3mm adhesive, its not enough for what you want it to do..
:thumbsup:
It was only for calculation purposes, i have a guide for a 3mm solid bed or a 6mm solid bed, so i was thinking 6mm notch would give me 3mm solid. Don't know if thats correct or not but just trying to work weights out which is a bit confusing:mad2:
If I was you Budda I would take TJ's and S/R's advice, get your substrate mechanically fixed to avoid the tile in the eye.
:thumbsup:
Ha ha!! will you stop keep going on about backerboard, mechanical fixing a board is out of the question. If this was the only way I would have to brave up and tell her NO! :lol:
:thumbsup:
Wait a mo! waiting for an answer on the light weight block option. If its backers its a NO!! she can have mosaics for her feature wall lol!:lol:
Why is it out of the question to mechanically fix??
The fixings would have to go through the plasterboard into the block, plugged and screwed, Im guessing at about 10 per sheet (600 x 1200 ?), 6m2, would be a nightmare:yikes:
Theres more than one way to do it correctly, i am open to other options such a taking the dot and dab plasterboard off and fixing to the lightweight blocks. Can any one tell me the limits for light weight blocks and preperation please
Taking the dot and dab off and fixing to the lightweight blocks is mechanical fixing? Thats what we are trying to advise you bud.
:thumbsup:
:thumbsup:
Sorry I thought mechanical fixing was drilling and fixing not sticking, getting my wires crossed then:lol:
What blocks are we talikng about ? thermalite / other, either way, as long as they're in good condition they're going to be strong enough iirc, I'll try and dig outthe data sheets once we know what blocks you have :thumbsup:
You should be able to prime them and then tile using a SPF adhesive.
But wont this involve removing plasterboard, skirting and sockets etc...Now that sounds like a lot of work. You will need to clean the blocks down from all the plasterboard adhesive too .
Am I Pushing It?
Tags Tags
usa
buddha1964,
buddha1964,
buddha1964,
buddha1964,
