Discuss Shower tiling in the UK Tiling Forum area at TilersForums.com.
N
notaclue
Hi all
Need some help please.
Fitting a new shower enclosure, 1200 wide, half the backing wall is old plaster on stone in fair condition but needs a skim, other half is an old doorway that someone has blocked off with std 12.5mm plasterboard & is unfinished (was hidden behind some panelling).
I would need to skim the plasterboard to bring surface flush to wall.
Intend to tile this area with medium weight ceramic tiles, what suggestions for preparing & finishing ready to tile?
Thanks in advance :helpsmilie:
Aspect Tiling
303
If you do go down the plastering route I would strongly advise you to fit a waterproof membrane to the shower area such as durabase or homelux waterproof matting. Have a look on wetdecs site for durabase. These products will prevent any water penetration through to the plaster which would cause the de-bonding of the tiles. These matting systems are easy to install with a thin bed of flexible adhesive. They can be tiled on as soon as they've been installed as well.:thumbsup:
Bartlett
I would remove plasterboard then batten out the wooden door frame (with extra noggins if needed), level to the plastered side, then screw aquapanel to door frame and wall plug the aquapanel to the plastered side and tank tape seams.
Think is what I was thinking :thumbsup:
Avoid plastering, just create a good level waterproof surface to work on, although this assumes you have enough room for battens and boarding?
A
aqua blue
notaclue. How you do it in the end is up to you. Personally I would do it the way I suggested. I would (don't normally do this) fix the aquapanels horizontally which should work out well with you measurements. The reason for this is because you have a composite wall. Two different structural halfs. This method would bridge that possible weakness. Do it once do it right. Don't forget the tanking tape.
Reply to Shower tiling in the UK Tiling Forum area at TilersForums.com
  • Sticky
