Minnie
Due to another little mistake, I've realised the tiles I'm carrying through from the main wall to the sink are slightly taller. As it would involve a very small cut which I'm unable to do, is it acceptable to sink the vertical tile behind the horizontal and hide my little mistake? (I think I should have bottom of tiles on main wall to matching one on sink, but I decided to match a grout line instead) 😳
and yet another question....
My middle wall behind sink is 32cm and the tile I'm using is 25cm. Do I need to do two little offcuts either side of the 25cm or can I do a 7cm section into the corner?
If the former, then does that mean I have to do the same with the horizontal tiles on the ledge and the vertical tile above the sink so I have matching grout lines?
Questions, questions :smilewinkgrin:
