Discuss Used Mapei Mapeker underneath insulation boards...... will it ever dry? in the UK Tiling Forum area at TilersForums.com.
Q
Qwerty
Never fitted down insulation boards before, but this morning I fitted down some warmup cement faced insulation boards using Mapei Mapeker
I used a 10mm U-notched trowel to ensure a decent coverage. I made the mix up a little looser than normal as I was paranoid it was going to go off a bit too quick! I am now worried that I may have made it too wet and it wont set. :mad2:
Am I correct in saying that as it is cement based adhesive that it will go off eventually and that air isnt required for setting .... or .... Is it possible to make it too wet so it will never set? :confused_smile:
Reply to Used Mapei Mapeker underneath insulation boards...... will it ever dry? in the UK Tiling Forum area at TilersForums.com
  • Sticky
