Discuss Best Tile Cutter 2009? in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com.
honza1
228
London
go for a sigma , monty or the rubi ti cutter, dont go for the rubi ts range as they are very limited, ie you want a cutter with a moveable breaker.. i have owned or used all these cutters plus the rubi tx range but not the Ti and the best are the monty and the sigma... p.s read daves review on the rubi ti .
I am bathroom fitter. I need to buy new cutter too.
Definitely able to cut 600 mm tiles and strong enough to cut porcelain.
For pro/often use but not dayly bases.
What is the limitation of TS?
Is TS plus any better appart from breaking power? I though I would buy this one.Seems to be good enough for every job.
TI looks nice but
1)does not still have case in yeaar 2009 april and it is needed to my opinion for transportation(things can fall and so...)
2)am warried about that it might be too strong for some ceramic tiles- crashing them (as statet by others)
Can you help?
DHTiling
Re: Best Tiler cutter
Hello and welcome...
The rubi tx700n is perfect for what you need....I have one and swear by it..
RUBI TX-700-N
- Ideal for cutting: heavy duty porcelain
- Swiveling ruler makes diagonal cuts easy!
- Also suitable for cutting standard ceramic tiles
- Maximum cutting length: 28" (71cm)
- Will cut a 500 x 500 mm tile diagonally
- Cutting thickness: 1/4"-13/16" (6-20mm)
- Separator power: 2,204lb (1000kg)
- High performance moving breaking system
- Angular measuring system for 0-45° cutting
- Lateral stop for repetitive cuts - straight & 45°
- Direct vision of the scoring and cutting line
- Complete with shockproof case
- Includes 10mm & 18mm scoring wheels
- 5 year guarantee
Weight 22.2 kg
Click here for video of TX-N machine in action
TradeTiler.Ltd Rubi TX-N Manual Tile Cutters
andy-p
543
Central Scotland
dave !! i have a rubi tx1200 and i swear at it..:lol: honza i would recommend the montolit mp75 , its the best cutter in my collection but if you want a case then go for the rubi tx 700 as dave recommends ,it will do the job.. :thumbsup:
mart08
I have the TX 700N and have no complaints:thumbsup::thumbsup: I also have the pocket rubi 40 for smaller jobs and is a great bit of kit for just over 30 notes.
martin & brock
all our tools are rubi,good cutters,no major problems
jay
sigma large with piveting base for cutting 45s thats my prefered cutter:thumbsup:
Dave Ramsden
I agree with Dave. I use my TX700 for all porc jobs and anything around the 600mm size. I recently bought a Ti but Im not to keep on the faffyness of the breaker plus it shatters basic 6" tiles.
When Im stuck for space and only have normal bathroom tiles to fix I use my TN600+ which Ive had for nearly 10 years and is still going strong!
honza1
228
London
RUBI TX-700-N
- 5 year guarantee
Weight 22.2 kg
YA mon!
made my mind.
Buying this.TX700N
will do all jobs , anp pay for itself within days and last many years.
Thanx Espeialy to DAVE.
Reply to Best Tile Cutter 2009? in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com
