monty
Hi guys
I'm about to buy a new manual cutter from trade tiler, But I'm a little confused in why the ts-60 is more expensive than the ti-s-66.
ts-60 .... Same as TS 60 but with a newly developed 750kg pressure breaker (standard breaker is 400kg).
Can be more effective for porcelain tiles
Cutting length of 660mm. Also supplied with case and 1 x 6 mm wheel and 1 x 10 mm wheel.
Will cut a 460mm x 460mm tile diagonally
Overall case dimensions (mm) 900 L x 410 W x 130 H
Ti-s-66 ..... Fast and highly suited to heavy porcelain
- 1000 Kg breaking power
- Cut length 66cm (bed takes 70cm tile)
- Cut thickness 6 mm to 20 mm
- Forward cutting (PUSH) scoring
- One piece alloy base plate
- Sprung steel top plates
- Ruler bar swings to any angle 45 deg both ways
- Indexing angle stops at: 0, 15, 30 and 45 deg
- Includes 1 x 10mm scoring wheel
- Weight 11 KG
- Pads on underside of breaker prevent marking
Which one would you buy??
Any feedback on any of these cutters would be much appreciated.
Cheers
- Weight 11 KG
Cheers
