TS 60 plus
  • Thread starter Thread starter Versatile69
  • Start date Start date
  • Tags Tags
    usa
V
Versatile69
Tiling a bathroom at the moment using 500mm x 500mm x 10mm porc tiles.
The TS 60 Plus with 8mm / 10mm scoring wheel has been working fine with 90% clean breaks, however for some reason today it won't break clean at all, tried with off cuts but just ends up in a mess. Not a problem as I have been using a wet wheel to get on with the job, but I'am left wondering why the TS 60 has lost its mojo all of a sudden?
Have a TS 60, not a plus and found on the breaker a steel bar had come come loose so was breaking the tile, check for any fixings that may have become slack.
I will check that out cheers, I have a friends T60+ as well so I'll see if there is difference.
Check for play or wear on the under arm pin..the arm that rises as you pull the snapper..:thumbsup:
Hi Versatile,
Where do you live? I will get one of my Sales Reps to have a look for you.
Give me a call 07764786508
TS 60 plus
Tags Tags
usa
Versatile69,
markfromrubi,
Versatile69,
markfromrubi,
