wet saw vs angle grinder
As with all tools - buy the best that you can afford at the time. Have 3 wet saws now, 2 rubis and a norton clipper. The biggest rubi is a table saw with a 300mm blade and a 2000 watt motor. Will cut through anything, even flagstones and bricks.
Angle grinders are always handy - again if you can afford then spend the extra money and get a variable speed one - then you will be set up for polishing when you do natural stone jobs - eg polished edges - for example when fixing limestone or travertine into a window reveal. Just butt joint them , then round off and polish the rough edge. Looks far better than tile trim or leaving bare edge. You can charge more too. Look at spending £120 plus for a decent variable speed grinder.
Also to add - a variable speed grinder is also much better for sanding than a conventional sander - many differend grades of sanding pad available. Very usefull for taking emulsion paint off walls prior to tiling.
hi guys i bought a plasplugs one when my rubi went down and was amazed at the torque from it ,used it for a while then!
have you seen the dewalt d24000?? ive used one with a marcrist wheel and it was the mutts nutts way better than the rubi radial we had set up there, got a really long bed on it as well i deeply deeply aspire to one of these now after checkin the specs and seeing they beat the equivelant thousand pound priced rubi and was only 650 new
tiler burden,
ceramic art ste,
tiler burden,
ceramic art ste,
