monkeyhanger
I am doing out my bathroom in quartz 30cmx 30cm tiles which weight 2.15kg each.
Im tiling 2 tiles high around the bath (so a height of 55cm (below bath rim) to 115cm exc gaps and trim).
The wall that spans the length of the bath is plastered 12.5mm plasterboard which was cemented onto blockwork.
Does the weight rule of 20kg/m2 apply when the tiled area is only 0.6m in height?
Should I be hammer fixing some studwork to the block wall and then aquapanel on top of the studwork for the tiles to fix to? This would bring out the tiled part of the wall out by 60mm-ish, which isn't ideal.
What would a pro do for a job they'd be putting their name to - tile straight onto what's there as it's only 60cm tile height, or put the studwork in?
