Discuss Uneven wall next step in the Canada Tile Advice area at TilersForums.com.
A
Ademii21
Hi All
Please can you help? I am in the process of getting a new toilet done.
Attached is the state of the wall after the previous tiles have been removed.
Please what should be done to get a smooth professional tile work done.
8443B583-EA74-4D15-A33C-AA9F58ACC467.jpeg E7D869C5-8FFB-4747-A028-7AD829FB165A.jpeg
A
Ademii21
Thanks everyone.
Dot and dab? Ok will ask the plasterer
I have much the same type of wall elsewhere and I really need a second opinion
At 1st the installer mentioned bonding and then bonding and skimming. The plasterer then says plastering is better then goes on to say he wil do bonding and cement. It’s really getting confusing as I don’t know which is which and which is better.
This is for a bathroom with shower with big tiles 60x60 on the walls. Also the shower accessories is going to be embedded.
Pls help. What’s the best to use to get the best wall for tiling all I described up there?
Thank you very much
Attached is the state of these walls
2A23937F-4082-4509-9F13-51BBB0276945.jpeg 3BFD40AF-6405-4C32-B0B4-80DBBB3B2843.jpeg 6CF7AC53-EC10-4A73-AC13-7122A1E949F0.jpeg E7220932-0042-41CE-A44A-2EF9B4329842.jpeg 8F4663FD-0053-4919-BC5F-0EEA94B8BCFB.jpeg DB25C1A4-ECDA-4275-B852-902B59F8765D.jpeg
Reply to Uneven wall next step in the Canada Tile Advice area at TilersForums.com
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
  • Question
