Rizzle from the Portizzle
well have been told all sorts about ufh so decided to test for my self i wanted to know the difference
between a 10mm tile and a 4.8 mm tile so i got 2 x 1 m2 mats from thermonet then used 12mm insulation boards laid the mats out then tiled one side with 4 600x600 10 mm tiles the other side i tiled with 2x 1200x600 4.8mm tiles total area 1.44 m2 then we had to make a roof and walls to cover the area to be tested
to keep the cold draughts out .
next we set the thermostat to 39 % to see how long each would take to get there and how much energy was needed. then we turned them down to 23% and let them run for 3 days so we could compare the difference.
a big surprise for me was how fast the 10mm tile cooled down compared to the 4.8mm .
here are my findings .we used a 3I warm up stat so we could record the results .
day 1 heat up to 39% 10mm tile 6.3 hours 6.8 kw energy used
day 1 heat up to 39% 4.8 mm tile 4 hours 3.9 kw energy used
day 1 heat up including turning down to 23% 24 hours 10 mm tile 9.41 kw energy used
day 1 heat up including turning down to 23% 24 hours 4,8 mm tile 5.82 kw energy used
day 2 running at 23% 24 hours 10 mm tile 6.41 kw energy used
day 2 running at 23% 24 hours 4.8 mm tile 6.03 kw energy used
day 3 running at 23% 24 hours 10 mm tile 6.41 kw energy used
day 3 running at 23% 24 hours 4.8 mm tile 5.59 kw energy used
total energy used 10mm tile 22.22 kw at 10p a kw £2.22 m2
total energy used 4.8 mm tile 17.61 kw at 10p a kw £1.76 m2
here are some pictures
