Type of glass for shower screen?
Morgan Ereku
Hi, I'm putting in a wetroom shower screen.
It's going to be 220cm x 90cm
Any advice on
1. Whether the glass needs to be a special type? Can I just get hardened glass from the local merchants or should it be specially treated to help with limescale etc (or is that just a gimmick?)
2. How thick - Is 10mm right, or maybe 12mm?
Planning to use transparent blocks to hold the glass. These were a recommendation from someone.
Transparent Plastic setting and Distance Blocks - https://www.wholesaleglasscompany.co.uk/acatalog/Transparent-Plastic-setting-and-Distance-Blocks.html
Cheers!
The glass should be toughend and most off the shelf screens are 8mm, but if I supply bespoke sizes I tend to go for 10mm especially when not using a support arm.
The coating actually works and helps to keep the glass from attracting soap and lime scale, although I suggest customers to use a squeegee after each use.
Yes toughened safety glass with an anti calcium coating is what I’ll spec. Again 10mm is preferred. My local glaziers can do any size glass for me.
Not all glass is the same though. The opacity varies and even the rigidity of glass of equal thickness’ can vary. Also when you look at the edge of the glass, the 10mm bit, this can be almost clear.
Tanking and Wetrooms
Morgan Ereku,
Morgan Ereku,
Morgan Ereku,
Morgan Ereku,
