Currently reading:
Travertine edging
Discuss Travertine edging in the UK Tiling Forum area at TilersForums.com.
bigmal
Hi guys
Hope you don't mind a DIY type invading your very professional forum!
Done various jobs over the years for myself and mates, and always been pleased with the results. Only use a cheapo electric wet cutter, but seems to do the job.
In process of rennovating bathroom - plaster was dodgy, so that's all off. Plan to fix HardiBacker to timber studs, but a mate is going to replaster one internal (brick) wall traditionally.
I would like to step up a notch and go for Travertine... so my question is about the cut edges, eg the return into the window recess. I would normally use plastic/metal edging trim, but I'm guessing this would ruin the effect of the Travertine. What do you pro's do? Leave a bare edge (perhaps sanded???) and just overlap the corner joint?
Any advice gratefully accepted!
Big Mal
DHTiling
Hello and welcome...
You can finish the edges with various grit sanding pads to a nice enough result and slight chamfer to remove the sharp arras edge.
But if you like you can also buy some diamond hand pads designed just for this type of edge finishing.
Montolit Diamond pad set
Diamond hand pads for smoothing the edges of any type of:
- Marble
- Granite
- Porcelain
- Stoneware
- Ceramics
Blue = Medium grit
Red = Fine grit
Can be used wet or dry
Tradetiler tilers Files & Rubbing Blocks
I like to try and gett he edges as close a finish tot eh tile surface be it honed or polished and if customer requires it then i also bull nose the edge but for a DIY job then those hand pads will make light work.
Reply to Travertine edging in the UK Tiling Forum area at TilersForums.com
