L
libra
Hi I am just renovating my downstairs cloakroom, adding a steam shower quadrant full enclosure, shower is full unit and has its own walls from all sides. cloakroom has one external , two plastered walls, one plasterboard wall. to hide waste and plumbing pipes i have made stud wall on a plastered wall and topped it with external grade plywood. I thought as this will not getting the shower or water contact, plywood should be fine and didnt use to tile backer board etc. I havent tiled it yet, will be tiling real stone marble. also used plywood to enclose wall hung toilet frame.
is it ok to use plywood or i must use tile backer board or can i prime it with something?
Thanks in advance
Thanks in advance
