Currently reading:
tile over anhydrite screeds
Discuss tile over anhydrite screeds in the UK Tiling Forum area at TilersForums.com.
toshtiles11771
Hi
Looking for a bit of advice, I have been ask to tile a kitchen and shower room floor in a new build by a contractor. Just found out today it has a anhydrite screed on the down stair floor.
I have looked on the net for information and it said that it has to be mechanically [FONT=arial, helvetica, sans-serif]abraded and an appropriate primer to be used.
Just looking for any information or advice from anyone who has tiled app on this type of screed.
Tosh Tiling
[/FONT]
Ajax123
1,213
Lincolnshire
Tanking in the shower. Ideally a joint in the screed between the shower and the non shower but if its not there tank beyond the bit that will get most of the water. no tanking required elsewhere.
1. Abrade the floor as already described ( I usually go for 60 grit but 40 is fine)
2. Make sure the underfloor heating is comissioned and run ( properly!!)
3. vacuum any remaining dust
4. Test it to make sure it's dry enough
5. Tile it.
If tanking is used you are fine to use a flexi cement adhesive ( I would Recomend thisin the wet areas anyway)
Everywhere else you do ot necessarily need a primer
Here is a listof adhesives which can be used primerless
CSA from granfix
tile to Gypsum from norcross
gypfix from n&c nicobond
h 40 Eco ideal from kerakoll
benfergyps from benfer
There are probably a few others that I don't know
Reply to tile over anhydrite screeds in the UK Tiling Forum area at TilersForums.com
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed most of our floor to accommodate tiling 800x800 porcelain over an uneven floor. The gap from defrac...
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
