Discuss splashback in the UK Tiling Forum area at TilersForums.com.
A
anderson
Hi all .
First post so be gentle . I,m doing a window splashback using 10cm tiles , and am trying to figure out how best to lay tiles out . Because I have dado rail on joining wall I would like my tiles to finish level with it because I think it looks neater , This would mean that i would need to cult 1 tile approx 7cm after allowing joints . If i start with smaller tile on bottom it would leave a 2cm gap under the window sill , as it,s approx 9cm from the upstand ( thats what i,m tiling off ) and the bottob of the window sill .
How do you think it will look if i finish with cut tile at the top , i cant see another way around it . All advice greatly appreciated
Neil
A
AllurePTS
Hi all .
Neil
It's hard to visualise Neil, ....you definately want to avoid narrow cuts if at all possible ....so from what you said, I think the 90mm at the bottom and 70mm at the top is the best way .....stongly advise you use tile trim on your top edge though - it will be very hard to get a good finish in that situation otherwise :thumbsup:
Just a thought ....obviously I don't know the details, but maybe changing the size of your spacer could help ???
Also - do be sure to check that your upstand is 100% level mate :thumbsup:
Welcome to the forum
macten
1,158
Nottingham
Last splashie I did I didn't use trims. Owner still had some paint left from the kitchen walls so I painted the tops and sides of the tile and it looked great.
Also meant I could move a socket into the field of tiles, and make good the hole in the wall.
Reply to splashback in the UK Tiling Forum area at TilersForums.com
