Currently reading:
Some general questions
Discuss Some general questions in the UK Tiling Forum area at TilersForums.com.
E
ellisn
Hope you can answer a 'couple' of questions for me, no doubt I will be adding a lot more in the future..
When laying tiles the advise given is to lift the occasional tile to check adhesive coverage. Do you then just lay the tile back down or rework the adhesive with the trowel first?
If you have floor tiles butting up to wall tiles do you grout the join or leave a gap and use sealant?
I plan on laying 12mm ply or 6mm backerboard onto a chipboard floor in my en-suite, should I use BAL single part flexible along with the screws to fix it down?
I am using porcelein 333x333 wall/floor tiles with 4mm spacers on both floor and wall with white grout. The products I am concidering are the following:
  • BAL Prime APD
  • BAL Single Part Flexible (Both floor and wall)
  • BAL Super flex wide grout(Both floor and wall)
Does this sound OK?
Sorry for so many questions first thing and thanks in advance for any help.
Neil
slinky
possibly better to use 18mm ply, screw down every foot,yes bal prime is best.
when butting floor to wall leave expansion gap of a few milli as the ply will swell so use silicone not grout .also best to rework adhesive when checking adhesion,
use rapid set flexi for floor this will cure ready to grout in 3hours,the grout is correct too.prime walls also if using same cement based adhesive.also if porcelain a tile sealant before grouting may be in order,good luck.
E
ellisn
Thanks gents
Would 6mm backerboard be OK? I could go with the 12mm backerboard but from reading some lit it seems that the 6mm comes in 1500 x 900 which would mean only 4 panels needed for my 2500 x 1800 floor as opposed to 5 of the 12mm 1200 x 900. That supposes that it is these sizes held by Topps. I would probably have to cut them down to 1250 at Topps in Swindon to get them in the Polo though.
I might also be going for Granfix 1 Part CFTA adhesive instead of the BAL as non-trade prices look a lot better. I can get 20kgs for £16 but I doubt non-trade BAL SPF from TOPPS will be anywhere near this low, will check tomorrow. Have to go and have a wisdom tooth out now so as much as I try; tiling is not the order of the day :cryin:
Cheers
Neil
Reply to Some general questions in the UK Tiling Forum area at TilersForums.com
  • Sticky
