Currently reading:
Silicone internal corners...
Discuss Silicone internal corners... in the UK Tiling Forum area at TilersForums.com.
R
Rich
I did a repair on a Huge house a few months ago because the tiler had not sealed properly around the shower tray, water had got behind the tiles and ruined the plasterboard. I got a call from the lady the other day asking if I could go round and take a look at the other shower room, the silicone had gone black and could I replace it. As I was only working round the corner I popped round yesterday. I wish I had taken my camera...
The tiles were hanging off the wall, huge cracks along the grouting, the internal corners had been grouted then siliconed, the silicone was totaly black, the shower screen hadnt been siliconed and there were several holes in the grout. The worst part was that she told me that he is a 'really good tiler' :yikes: :mad2:
I told her that I could only do a patch up job there and then but she was going to have problems down the line. Let this be a lesson to all, grout in internal corners will crack and come loose taking any silicone ontop of it with it.
StanleyES
From the post's i have read it seems the general consensus is to leave an expansion gap in internals, then silicone internals and allow to dry, then grout.
This made sense to me (although i'm only a DIY'er). I was about to start siliconing the internal corners of my shower yesterday and started wondering about the butt joint that will be formed between the grout and the silicone. Won't this be a weak joint and a likely source of water penetration?
P
paulyoung666
not sure i have read you right here , but , the silicone takes the place of the grout :)
StanleyES
I thought that you pretty much filled the expansion gaps with silicone, (When you smooth it off with your finger). Once this had been done you then grout. This would mean the grout would simply butt up against your dry silicone joints. I just couldn't imagine the grout would seal against the dry silicone very well, i may well be wrong! Does grout shrink at all as it dries, if so this would definitely make the joint weak.
Whereas, doing it the other way round (As Scottley says) i can see the silicone will make a good seal when you smooth it off.
(My only thought with his method is that you need to have more accuracy applying the grout, making sure you get right up to the vertical joint without getting any in it)
What do think, am i worrying needlessly?
mikethetile
I understand your point
yes grout does shrink back a small amount as it dries but ive never known this to be a problem
I grout first leaving corner corner clear and then silicone when grouts dry
its just common sense to me as the other siliconing is done after grouting and I do it all in one
C
carole m
I want the internal corner in my shower just grouted with bathroom grout, i hate the sight of silicone, in many hotels in showers you never see silicone and in many new builds i do not see silicone, i have had silicone in bathrooms before and it has gone mouldy and looks bad, i understand i would have to re-grout every so often. if it is the case that it is because it is an internal corner. can ti be siliconed and then grout on top so as to make all the tiling look the some.
Hi Carole, the internal corners should not be filled with grout. The gap is filled with flexible silicone, so that it does not crack due to heat expansion. If it is filled with grout it will crack, it is not the way it should be done.
I'm not saying all contractors working on commercial projects such as hotels and new builds are bad, I have seen both excellent and some shocking examples myself.
If you are having problems with mould growth, then you need to ensure your background is prepared properly, use suitable grout protector, and a decent mould resistant silicone (preferably matching your grout colour, so it look like a grout line). Plus using a proper cleaning product, to remove soapy residues from grout and tile surface once every few months, should all add up to keeping it looking like new.
Also, if your tiler uses a silicone shaping tool, and cornertape/masking tape, then the silicone joint will be nice and tidy. Not sploged in and smoothed over with a finger, which I guess is what alot of people are used to seeing. So, just because your used to seeing something done a particular way, doesn't mean it is the right way to do it!!
Good Luck
R
Rich
I agree with both the guys above and I doubt you will find anybody on here that will say we are wrong. I really couldnt count how many rooms I have put right after thousands of pounds worth of damage has been done to the house just because the "tiler :)mad2:)" didnt know or couldnt be bothereds to use silicone.
It is not that we like to use silicone, it would be a lot easier and quicker just to grout the joints in but it WILL fail and water will destroy the wall and floor behind the tiling.
As has been said above, a neat silicone joint that has been done by a pro will blend in with the rest of the room, a bad messy joint done by a monkey will look awful.
jubba
All makes sense about using silicone in the corners.
So when you fix the tiles should a deliberate gap be left (use spacers) in the corner rather then butting the tiles together?
Mike
I'm just about to do a similar job, so let me just recap the above advice to make sure I understand,
For an internal corner I would need to leave a gap between the wall and tile of the tile depth (+ Adhesive) plus about 3mm on both walls, leaving a 3mm diagonal gap between the two tiled walls, then fill the gap with silicone?
i'm trying to understand your post, when tiling the first wall into the corner, leave a gap of 2/3 mm for expansion. when tiling the second wall into the same corner leave a gap of 2mm between the 2 tiles again for expansion. rake out any grout from the expansion joint prior to siliconing
Reply to Silicone internal corners... in the UK Tiling Forum area at TilersForums.com
  • Sticky
