Discuss Should I tile a non-straight wall straight? in the UK Tiling Forum area at TilersForums.com.
mpajones
Hi
Got a bit of a struggle going on between my head and my gut with this one.
I'm just about to start tiling a wall in my bathroom, but on mounting my baton horizontally, it has come screamingly to my attention that the floor and window are really quite far off the horizontal. It's a 100+ y.o. Victorian house, which I'd never expect to be straight anyway, but want to make sure that the tiling looks spot on.
What's the best way to handle this? If I tile on the level, the the window is going to look pretty darn odd, but if don't, then when the bath goes in (which will be horizontal), that'll look like it's on the( Removed bad language)
What's the best plan here?
Cheers
Matt
G
Gazzer
Always tile level, otherwise you will have issues elsewhere. Is the window unit level and plumb ?
Dan
Admin
1,318
Staffordshire, UK
As above, tile level but try to get a set out that gives you large cuts at either end of the wall and around the window too which should help hide the flaws in the wall. Bigger tiles can often help too. Your grout lines will need to be level and plumb though or else it'll really be an eyesore.
mpajones
Ok thanks!
Unfortunately the window unit is neither level nor plumb. It goes out about 10-15 mm in a vertical dimension across the width, and a similar amount horizontally over the height.
I'm refitting archtrave etc once the tiling is done, so can maybe make a visual "adjustment" with that.
Cheers for the advice (and sorry for the bad language in the original post!)
Matt
Michael kiss
If this was my house i would take the window out and put it back in plumb, then level reveals
Reply to Should I tile a non-straight wall straight? in the UK Tiling Forum area at TilersForums.com
