Sealant around bath against travertine
JulesA
Hi
I've looked and looked and I couldn't find an answer. But I'm happy to just be referred to an existing thread if I've missed it.
I need to replace the sealant around the bath. But the fact it's against travertine seems to make it tricky. I thought I could just buy any sealant until I noticed on the tube I'd picked up it said not to use with natural stone. Topps Tiles said not to worry, to just use anything, but when I called their helpline they said to make sure I used a neutral-curing one.
I've found a few posts where people recommend neutral-curing sealant, but apparently there are some neutral-curing ones you can't use. According to the technical specs anyway. I found Soudal Silirub+, but the S8000 that you can buy in Screwfix says not to use it on natural stone. It specifies Silirub+ S8800 for that, but I can't find where to buy it! And someone recommended Mapei Mapesil, but in their technical spec it says it's suitable for natural stone but that it might stain porous stone; so can you or can't you! And where do you buy it?!
I just want to replace the sealant without messing up the tiles!!
Hope someone who has had experience with using them can help.
Jules
Ottoseal S70 also from Broken Link Removed. Excellent stuff.
Thanks everyone
Can I check that someone recommending Mapesil meant Mapesil LM: Broken Link Removed Seems to be the stone one. Although the spec doesn't mention using around baths. I like it when the spec confirms what I want to do with it!
Or the Ottoseal S70 sounds good.
Looks like whichever one I go with I'll have to order it online though. Unless anyone knows of a London shop where I can buy them? None of the chain trade places, never mind DIY, seem to sell any to use with stone.
Jules
JulesA,
Old Mod,
JulesA,
Old Mod,
