Rubi breaking arm
windy313
Hi all
diy tiler here doing mainly my own work on rental properties
ive just bought a used ts40 from ebay
arrived today.... Problem is the cutting arm. You really have to push on it and it doesn't cut first time. My mate has one and it cuts tiles with a flick of the wrist with hardly no pressure. This one you almost have to palm it from above if that makes sense
any ideas on to remedy ? Can arm be adjusted or is this a common problem
tile cutter has seen little use
thanks in advance
Tested on Cheapo ceramics ... Only used small scoring wheel although it came with a larger one
Sounds like it needs oiling. They tend to clog up but easily sorted, just common sense really. Unbolt it, clean, oil then reassemble.
Great cutter the ts40 for ceramics.
Like ramie said, just clean it up but I'd just buy a new cutting wheel,they do wear away
Rubi breaking arm
windy313,
windy313,
windy313,
windy313,
