Discuss Retiled bathroom continually leaking in the Canada Tile Advice area at TilersForums.com.
Beepboop
I’m having problems with my bathroom I’ve had retiled and really need some advice. Sorry – slight saga ahead.
The property is flat on the top two floors of a Victorian terrace house in London, I guess it was renovated about 5 years ago. The bathroom is on the lower of the 2 floors, but the 2[SUP]nd[/SUP] floor of the house, and has wooden floors and partition walls. It has a bath with shower above it, the walls are tiled with slate and there’s a folding shower screen along the side of the bath.
There were previously problems with water coming through into the flat below when the shower was used, I put extra sealant around the bath and that fixed it. After a year the sealant became mouldy, so I thought I would re grout the tiles. Unfortunately as I removed the grout all the tiles just fell off the wall, they weren’t stuck on at all and were just being held up by the grout. At this point I thought I would get someone in as it was becoming a bigger job than I wanted to take on.
Because of come problems with the roof and gutter I’ve got people who work for the freeholder planned to come and do some work, so I asked them if they could do the bathroom, they came and said they’d redo the problem area for £200 using spare tiles I have, and assured me that everything would be sealed and leak free. The tiling looked OK when they had finished, but I was annoyed that the slate tiles were covered in a film of black grout. I started to polish it off, then realised I was doing work I had paid them for, and asked them to come back. I also noticed that no silicone sealant had been applied, so asked them to come and do that as well. I would have thought that was pretty basic – they weren’t bad about it and came the next morning, cleaned the tiling and .
After a couple of days to allow everything to set I said my (very annoyed by this point) tenant-flatmate could use the shower. It leaked into the flat below. I inspected the grouting and sealant and found holes in the grout and gaps in the sealant, it was mostly leaking in the corner, along the long side, and a little on the short side. I called them back and more grout and sealant was applied. It still leaked, more sealant was applied yesterday. I had a shower this morning and can still see water leaking through.
I’m now fed up with this whole situation. I didn’t tackle it myself as I didn’t want to do a half-assed job and for it still to leak, but I’ve managed to end up with that anyway. I feel like I should give up on them and get someone else in to do it. Is there any way I can tell for myself exactly what the problem is? Should I keep getting them in until it’s fixed, or can I get my money back off them and get someone else in to re do it? I paid them to sort the problem out, but it’s worse now.
Deleted member 9966
hi beepboop
do you have any pics of the back of the tiles you took off? By the looks of the wall behind the tiles, the people who have fixed the tiles have used a dot and dab method to apply the tiles to the wall. This is a bad practice and you should have a read of this thread http://www.tilersforums.com/tiling-forum/68065-say-no-dot-dabbing-tiles.html to find out why.
I won't be able to answer your questions myself as I'm not a tiler, but certainly there will be plenty of members along today and this evening who will be able to guide you and provide the answers you need.
GRR :welcome:
Deleted member 9966
This might not be what you want to hear, but you probably won't be able to solve the leaking problem until all the tiles are stripped off and the whole area is retiled properly. Because you are in a building where leakage could end up in somebody else's property, you really should consider the use of tanking membranes.
http://www.tilersforums.com/vbcms-comments/59863-why-there-need-tanking.html
http://www.tilersforums.com/tile-adhesive-grout/37983-why-use-tanking-compound.html
have a read of those threads. I am a huge advocate of tanking as my own en-suite shower leaked into the lounge due to poor tiling in the house when it was built.
I
Ian
I agree, though as they've done such a terrible job I'm not convinced they will ever sort it out properly. Certainly tanking has never been mentioned.
How much should I be looking at to strip / tank / retile a bath like that? The tiles reach up to the ceiling. They're black slate too, I think that needs to be sealed?
We don't discuss pricing on the forums. You may wish to post your job in this forum http://www.tilersforums.com/im-looking-wall-floor-tiler/ and qualified tilers in your area will be able to contact you to provide you with quotes.
John Benton
1,138
Leeds
The wall needs stripping of tiles and re-fixing. As previously stated the wall should be tanked to provide a watertight seal around the area. I wouldn't be convinced that the people who did the job are up to repairing the wall correctly if that was their attempt at repairing 1st time. If what you say is true about the kitchen floor then they are definitely not tilers, so you may have to go down a different route and get your £200 back and employ someone who knows what they are doing. Get references and speak to their customers or better still if they have anyone close to you where they have worked so you can see the quality of their work.
Good luck.
Reply to Retiled bathroom continually leaking in the Canada Tile Advice area at TilersForums.com
  • Sticky
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old...
