Removing Grout
wrl-2
Hi .. am sure many people have posted/asked this before. I did do a search but only had a few results?
So ... I've tiled my bathroom and have grouted with a Sandstone color Grout. The problem is, when the Grout is wet, it looks a better color than when its dry! ... so I've purchased a couple of bags of Grout (Brown in color) ready to re-grout my bathroom.
I've purchased a Grout Removal Tool from B&Q and have started using it.
The Grout Removal Tool requires a hell of alot of hard work and it's not that easy to use.
I've already made a few chips in some of the tiles.
Am I using it incorrectly?
Is there an easier way to remove Grout?
How much of the Grout do I need to take off to re-grout?
there isn't really a better tool without going to a fair bit of expense,you could have tried using a colour intensifier on the grout it would also seal it from changing colour when wet!
the best tool to use is a Fein Multi Master, with a diamond grout removing blade.
A Fein can be hired from most good tool hire shops for around £30 a week. The blade can be purchased from Trade Tiler for less than £30.
I'll Google it. I'll see what color intensifier I can get ... thing is, like I said, the color is Sandstone but looks like wet sand color when wet and it's the wet sand darker color I now prefer, as ... when the Sandstone color is dry it blends in with the color of my tiles (too much).
I can't keep my Grout wet 24/7 hence I want to remove all the Sandstone Grout and re-Grout with Brown (nearest match I can get to a wet sand look)
Removing Grout
wrl-2,
wrl-2,
wrl-2,
wrl-2,
