Recommend Porcelain Cutting Disc For Rubi Wet Saw
Rubi do their own blade for porcelain but not one I've used, try ATS for good priced blades.
What wet cutter is it? I'll be able to have a quick look for you in their catalogue if you haven't got it to hand. Won't be until Wednesday that I'll have it to hand either though. If it's the ND-180 then I'm hearing good things about the Pro Viper by Rubi. I generally find less issues with the Rubi blades than the Vitrex/Tilemate blades.
Thanx but I've nearly finished now, then I'll be selling the cutter, so no need to replace the blade now
Hi I have got the rubi DC-250 cutter and have a wet diamond blade on it but I am thinking of buying a dry cutting blade for it as well I'm looking at the viper diamond blade , has any one used this if so good or bad idea ?
gooty,
Riccardo Pinna,
gooty,
Riccardo Pinna,
