Price Check Please
mickmcc
PRICE CHECK ON NEARLY 4 SQUARE METRES OF GLASS MOSIAC TILES FOR A SPLASHBACK, LABOUR AND MATERIAL ONLY, WHAT DO USE THINK?
Could only give a ballpark figure without seeing what there was that needed to be cut around and wall condition, but really, it's a days work max, plus going back the next morning to grout.
£230 inc mats.
fekin mate or any1 who's there. whats the standard way of fixing and cutting glass mosiac, is it just a simple normal job or do i have to use different materials. eg: grouts and addy,
normal white addy and grout, 3 mm trowel. wet cutter for cuts. make sure wall surface is flat and not bumpy as mosiacs will show every bump or hollow
£230 inc mats.
make you right . 250.00 . mosics are a pain in the bum
if they have a backing cut them upside down.take care to protect the face from scratching on the wetbed.use a mosaic trowel so that ridges of addy cant be seen.
when you have cut your hands enough times think about wearing some gloves:lol:
do splash backs as a mian bit of tiling would say as fekin did £230 including trims adhesvie and grout
£230 inc mats.
I have to disagree with Fekin a bit. I think it is more than 1 days work - assuming that it is 25mm glass mosaic. I have just done a very similar job and it took me two days. Very fiddly job, you really need to use something like mosaic-fix as it's glass and that means effectively going back the next day to grout. There are an awful lot of grout lines to keep clean! I have a montolit dry cutter and was able, in the main, to cut the tiles with this but there are times when you will need nippers. I didn't use a wet cutter at all.
I have pictures somewhere in another thread I posted yesterday if you want to have a nosey.
Grumpy
how do you cu mosics. i bought a mosic nippers and it wasnt a good make one but it shattered them. i had to score each one with my dry cutter ad them nip each one.
can you put them though a wet cutter with a marcrist blade.
What do you do
What do you do
I use my montolit dry cutter! It has a breaker system suitable for cutting mosaics. If I need to cut individual tiles I use my normal rubi nippers. Didn't have a problem , though so of the tiles don't cut exactly straight sometimes. I think though that is the nature of the tiles.
Grumpy
Price Check Please
mickmcc,
grumpygrouter,
mickmcc,
grumpygrouter,
