Out door stone fixing
N
nipper76
Hello folkes
I have been asked to price up a job it's a external tiling job on to a concrete slab that is 10" thick laid to a small fall away from the building the slab is reenfoced.
Due to door sills I be building up a thick bed approx 22mm to finish at correct hights.
The stone is 600mm wide random length 22mm thick stone.
My question is can I lay this on a cement and sand bed ? And what mix would be recommended ?
White cement I guess ? And should I add some sbr to the mix to improve adhesion
Also what about decoupling mat (ditra or equiverlant ) any advise greatly appreciated
no need to use white cement if you are thinking of laying in sand and cement.
Make sure you put a cement slurry coat on the back of the tile as you fix them.
22mm bed is a little thin for S&C but I have done it in the past, it is not ideal.
I would use a 4:1 ration for the mix as it is so thin. I would also use an sbr to prime the concrete first.
You can add Ronafix to your mix, that will help with a thin bed.
That's a tip I stole off our very friendly Porcelthin supplier uncle Ray.
I'd also look at using something like Ditra Drain 8 as opposed to Ditra 25
That alone will give you a 10mm lift in height and provide good drainage.
And decouple your stone from the slab.
Then you have far less to make up, and be able to use a ptb adhesive instead.
It's Just another idea.
Hi 3_fall
What sort of cost dose the ditra drain8 work out per a meter !
anyone tried these sort of thing?
Adjustable Self-Leveling Floor Pedestal SE Silent - http://www.pedestal-eternoivica.com/en/products/adjustable-self-leveling-floor-pedestal-se-silent-with-bi-material-head
nipper76,
One Day,
nipper76,
One Day,
